Scott M
PNW
'23 Bronco Black Diamond, '99 BMW M3, '88 BMW 325i
Go do it!
This was at an event at Dirtfish hosted by the NWRallyAssociation Northwest Rally Association
Three of us Broncos invaded and had a great time. Lots of people came up to us amazed at how well these things dance around!
Thanks to @ezapar 2 for encouraging me to sign up!
Ford Bronco Rallycross in a Bronco!?! Rallycross Fest 2025 (3)
Ford Bronco Rallycross in a Bronco!?! Rallycross Fest 2025 (2)
Ford Bronco Rallycross in a Bronco!?! LMM-20250726-3
Ford Bronco Rallycross in a Bronco!?! 1754409710727-w2
Ford Bronco Rallycross in a Bronco!?! LMM-20250726-5
Ford Bronco Rallycross in a Bronco!?! Rallycross Fest 2025 (1)
Ford Bronco Rallycross in a Bronco!?! tidepool-4
Ford Bronco Rallycross in a Bronco!?! LMM-20250726-10
Ford Bronco Rallycross in a Bronco!?! tidepool-6
2021FordBronco2
Jo
Nampa, ID
2024 Ford Bronco Big Bend
Go do it!
Looks like fun, need to get out there myself and do it.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
What modes did you try and what worked best for you on this track?
Scott M
Scott M
PNW
I did the first run in Sport mode with the AdvanceTrac button held down until it gave the 'Off' indication. The 4A of this mode definitely helps turn in, but acceleration is severely limited when wheel slip and/or rotation is detected - I'd give full throttle and it would cut power and be laggy on the exit resulting in not being able to hold a slide.
On the second run I switched to Baja mode (added via Forscan) with AdvanceTrac button held down until it gave the 'Off' indication. This was certainly the ticket and would allow lots of power and sliding on the exit -so much so that at first I didn't adjust my driving in time and had a very exciting but sloppy run. I ran it in Baja w/o AdvanceTrac for the rest of the weekend and learned to be a bit more graceful with the throttle.
TeocaliMG
Plymouth Michigan
2021 Bronco Badlands non-sas 4 door manual
Reminds me of old conversations with this guy back before the Bronco even released, anyone remember him?
He wanted a Bronco to race rally like his Mitsu Pajero Evo. Not sure if he ever got one or ever raced it. I was always curious how it would perform against the Pajero or other rally platforms!
Ford Bronco Rallycross in a Bronco!?! 1754423520239-ld
Scott M
Scott M
PNW
VirginiaHeritage
Frank
‘25 Bronco HE
Nice! Way to represent.
This looks awesome and I want in.
I had a day and the Jameson is open. But still…
Scott M
Scott M
PNW
Nice shots! What PSI did you run in your tires?
I ran 24psi on the first day and 26psi on the second day. After looking at how much they rolled over in the photos, that was probably a little low. Will try 30psi next time and go from there
Ford Bronco Rallycross in a Bronco!?! LMM-20250726-2
BCKMRKR
James
NorCal
'22 Wildtrak 2-Door, '19 Miata, '15 M235i
Did the 3-day RWD class in a Subaru BRZ 10 years ago - most fun I've ever had in a car. Would be awesome to take my Wildtrak there. They would definitely need to do more course maintenance afterward simply due to the tire size (~205 vs. 315) and torque.
jensht
Germany
2023 Ford Bronco
Years ago when I still lived in Colorado the local rallycross organizer excluded SUVs and pickups as they had someone roll one and the organizers insurance said they won't cover any liability cases for vehicles with a high center of gravity. So just a heads up that if you plan to join an event, check with them that the Bronco is ok to take there.
