Quicker door removal and installation?
HotdogThud
mk6 gti, '21 MoarDoor
Do not remove without the use of the Ford door bags
You mean the door bags that you cannot buy unless you got them with your order? That was a nice gotcha to find out about after delivery..
"Oh, you can't actually buy those as an aftermarket accessory, we're sorryyyyyyyy"
I'm fine removing and installing them myself but I was just hoping someone had a creative way to make it faster or an aftermarket company developed a mod. The weight of the door isn't the issue, it's that they designed it with one bolt going up and one bolt going down. If both bolts went up I can imagine an easy mod to be more like the Jeeps where they just slide over the pins and the weight of the door holds it down.
thank you,
There's a pin on each flange that the door sits on before you tighten each bolt, and having one up and one down makes it so that one person can do it entirely by themselves. If this is really too much of a hassle, just open the doors next to a telephone pole and back up. Instant removal!
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
They can be purchased directly from Ford. Door Bags
BroncoA512021
Long Island, NY
www.facebook.com
Well holy schnikies! Glad to be wrong about that (didn't used to be that way)
Never changed. The door bags that became unavailable were the "onbaord" bags with a very expensive strapping system.
Toccoa
Isuzu Rodeo Sport
I've found those available online from a dealer, but the strap/harness is $500 and the doors are around $170 a piece. You'd have to REALLY want to take your doors off and store them onboard at that price.
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 23 Bronco
BroncoA512021
Long Island, NY
www.facebook.com
Only thing is, those bags are the "garage bags", not the ones that have the strap system to securely hold them in the cargo area.
Nobody actually straps the bags in. We leave them at home
KyTruckPlant
Goshen, Ky
I have once or twice, but decided it was too big a pain in the butt, so now I do the same.
JonDW29
Jon
NoVA
'16 F-150
Only time I could ever see using this is if I was traveling, and that's a maybe by itself.
KyTruckPlant
Goshen, Ky
Yeah, that's the 2 times I used it, lol.
c-dubb
Calvin
Braptor, Palisade
Anybody else ever have trouble with the alignment pin not unscrewing for certain doors? Works fine on a couple of mine but not others. Doesn't matter if I screw it all the way down or just a thread or two.
Dmorty217
Derek
Venice FL
Camery
I don’t have this problem. Have you inspected the threads on the screws you have issues with to see if it was cross threaded? You could order some new screws if they are to see if the doors are what’s causing the issue.
