Quick install/remove mud flaps???
Scott R Nelson
Meridian, ID
I strongly dislike mudflaps on the Bronco ... but I need them.
I watched some YouTube video a couple of weeks ago about some mud flaps specifically for the Bronco that can be installed and removed in just a few minutes. I can't remember which were front and which were rear, but one position needed a small bracket added and the other installed directly. One position could be installed/removed with no tools and the other had a couple of fasteners for each one.
I've dug through a bunch of mud flap threads here and none of them mention the ones I'm looking for.
Anybody know of some quick install/remove mud flaps?
96dreamer
Tommy
St.Louis
96 Cobra, 00 Cherokee, 15 F-350, 16 Ford Fusion
RokBlokz are the only ones I've seen. I originally wanted them till the price came out @$400. Just bought some universal ones to throw on the front.
Moto26
Tucson AZ
Scott R Nelson
Scott R Nelson
Meridian, ID
Thanks for the replies so far. It looks like RokBlokz might be the ones I was thinking of. I'll study them a bit.
Once the price is high enough I can sometimes be persuaded to give up some functionality for a cheaper solution. We'll see on this one.
And in case anybody is interested, I discovered that you can look at your entire YouTube history at https://myactivity.google.com/
(I went back two months and couldn't find the video I thought I had watched. And apparently I've watched way too many YouTube videos.)
Scott R Nelson
Scott R Nelson
Meridian, ID
Found the video showing how to install the RokBlokz mud flaps:
Moto26
Tucson AZ
BroncMe
PA
BMWs
RIP Tawny Kitaen
Ford Bronco Quick install/remove mud flaps??? 1648927274043
Greymatter18
Phoenix, Az
Badlands Sasquatch
I installed these gatorback ones.
https://www.sharptruck.com/truck-hardware-gcn406f2-bk
I was looking at rokblokz at first as well (thanks to that video) but they were sold out and I didn’t want to wait to get chips. These are also cheaper.
The install was fairly easy and they seem secure. The bottom rubber portion is what is removable and slides out away from the vehicle. They don’t stand out too much and I like that they don’t have any logo or writing on them. Just be careful you get the right ones- depends if you have oem rockrails or not.
BluebroncoNC
Stroppe
2025 Stroppe Bronco & 1977 Bronco
Stroppe
IF you have an OBX, I put these on today, generic mud flaps from Autozone, cut with side snips, two screws into the running board. Turned out ok, I think. Someday, I'll replace those running boards with something more off road friendly and at that point, re do a mud flap modification.
Ford Bronco Quick install/remove mud flaps??? 20220519_160541
ticklemybronco
Josh
Salem Ohio
2022 Bronco 4-door
Once installed, our units remove/install in about 10 minutes: https://ticklemybronco.com/products...h-mud-flap-guards?_pos=2&_sid=a87892f98&_ss=r
Scott R Nelson
Scott R Nelson
Meridian, ID
I finally got some mudflaps for my Bronco. It's only been four months, right?
I went with the WeatherTech flaps. The price is reasonable at $55 per pair - $110 total plus tax. And they seem to be decent quality and reasonably easy to install. The hardest part of the installation was getting the Ford fasteners out so I could put the new WeatherTech fasteners in there. The fronts are definitely quite a bit more work than the rears.
Here are a couple of photos of them installed:
Ford Bronco Quick install/remove mud flaps??? KaWdGLG
Ford Bronco Quick install/remove mud flaps??? QDyuKZe
Now I just need to go find some mud and test them out. ;)
ryn0s3r1
Rick
SF Bay Area
2020 Tundra 1794 Edition 4X4, 2022 Ford Bronco
I bought and started to install the Gatorbacks, but after I test fit it, I thought they ruined the body lines of the Bronco and re-boxed them. Guess I’ll live with the rock chips. Anyone in Northern California interested it buying the Gatorbacks (brand new, front & rear, never been used) DM me.
