Question on Upgrading non-Sas OBX tires - Load Range & Size
Broncomike11
Ford Bronco
After about 1.5 years of driving with the stock tires on my non-sas OBX, I'm finally deciding to upgrade my tires ahead of the Colorado Winter.
Currently I'm looking to upgrade to 275/70/18 tires as to avoid the cost/hassle of replacing the stock 18 inch rims (I really wish OBX had 17...). Due to the smaller available inventory for 18 inch rims, I was curious if anyone here has had any experience/thoughts on the following items:
-Load Range: I see most tires at 275/70/18 have a load range of E. Though I'm in Colorado, most of my off-roading involves gravel paths and more open fields for camping, as opposed to true crawling or more involved off-roading activities. Based on what I've seen I feel C makes the most sense, but due to limited options I plan to stick with SL for the General Grabber AT/X. Has anyone had problems using SL tires for relatively limited off-road use?
-Size: I decided on 275/70/18 after reading through many posters on the board. However, I just saw a post on here with someone who successfully installed 295/70/18 on a non-sas OBX. If I plan to still use my Bronco for limited off-roading (and will be driving on ice/snow for 5-6 months out of the year), would anyone here recommend I go bigger than 275?
-Offset: I embarrassingly admit I really don't know much on this topic. Anything I need to know going from 255 to 275?
Appreciate any insight you all might be able to give.
amurphy9276
Aaron
San Angelo TX
2023 Ford Bronco
So I too have a Non-SAS OBX. I used to sell rims and tires. I put on a 2inch lift and I got rid of the stock rims and am upgrading to bigger tires. I did keep the 18 inch diameter though. So last October I was lucky enough to go through Ford Performance Racing School in Utah hosted by Michelin. We got to drive new Bronco's through everything but snow. I believe 275 70 18 is the biggest you can go. The ones I've seen running 295 70 18's have a lift on it. Going from 255 to 275 the tire is about and inch taller and 3/4 of an inch wider. Now I'm in Texas. Down here the bigger and the meatier the tire the better. That being said on any vehicle that I am taking offraod, through fields or anything like that I am choosing a 10 ply tire which is usually an E rating. I've had to many thorns and things go through 4 ply tires and just to have to replace them. That being said 275 is a good size. I would go with E rating (minimum 10 ply). Also, after that school and talking with the guys that put on the class the BF Goodrich TA K02 were always in the top 3 in each category. Most of those guys have them in their personals in Utah because of their year round performance. General is a good Tire just look at your other options. I'm a fan of TA K02 and I'm a fan of Hercules Terra Trac X-Venture for year round all around usage.
Aonarch
Jack Hoff
MT
Do NOT go load range E, they will ride like shit.
A SL/P rated tire will suit you well, unless you offroad in Colorado rock gardens.
If you do go offroad, and I do not mean gravel roads, then go with a C.
Duratracs are loved for their snow performance, but I've never owned a set.
I rock Firestone Destination AT2, which are Three Peak Mountain Snowflake rated and are wonderful on-road.
MNBigfoot
MN
I'd check FB market place/craigslist for a set of Badlands take-offs (33"/ 3 peak). You may find a set for $1000-1500, then sell your set for $150-300. This may save you money up front, but certainly opens up options going forward.
[DELETED MEMBER 27901]
I went with 275/65R18 Toyo AT3's.
Standard load rating
Same OD as stock - no speedo recal
1" wider than stock and looks 1000x better
I wouldn't go past 275 width on a stock setup IMO. My tires just kiss the front sway bar at full lock so I'd imagine the 295's would rub much more unless the offset was changed.
General does a 275/70R18 Grabber in standard load range if you're looking 33".
Mortonm
Canada
2022 Ford Bronco Black Diamond
I disagree with you on the Load Range E riding like trash
for years I ran LRE 235 85 R16 on my 1000lb lighter first gen xterra without any issues at all
AZ_Liberty
2007 Expedition
C makes the most sense, but as you note, there is one C rated tire available for every 80 E rates.
I hate SL/P tires. Soft and prone to puncture. I've had them go flat driving over a twig or cholla spine.
Had E rated tires on my Expedition, and drove with a screw in the right front for around 6 months before I bothered to get it patched.
The E rated on the Expy also improved the ride since they were stiffer, so less "wallow" around corners.
Broncomike11
Ford Bronco
Thanks for the information. KO2 was 100% my first choice, but the E load definitely seems a bit overboard for what I'm needing. I hear back and forth as to what using that means for the ride relative to an SL/P 4-ply. But obviously a trade-off considering durability.
Broncomike11
Ford Bronco
Very helpful - appreciate the advice. I've had the car for 1.5 years with relatively limited off-roading use, primarily for (1) camping or (2) access to more remote hiking spots within the area. Seems that would fit the category for not real "off roading", but also understand any trail that has a rogue sharp rock may mean a bad day for the SL tires.
Mortonm
Canada
If you plan any offroading at all I really think you want an LT tire C at least.
amurphy9276
Aaron
San Angelo TX
2023 Ford Bronco
I'm with you. Never had an issue with E tires riding like trash. I don't know anyone who has had a problem with a tire rating as much as a crap tire.
Jfman
jean
Canada
Accord
Personnally I am going to have a dedicated 18in snow/winter tire set.
Going for non-LT true snow tires. They dont comes in 275/70/18, have to settle for 275/65/18 or 265/70/18.
I plan to buy Blizzak or Xice CUV/SUV tires that are much lighter than LT tires and are 4 ply vs 8 or 10 ply for LT tires..
They shoould provide better compliance and grip and the lighter package should also save a little bit of fuel over LT's
I do not off road in the winter.
BTW: I was in Colorado last week and there are many set of spare OEM wheels for sale cheap in your state.
