Question About Spare Tire
xiLLeNtz
Ontario, Canada
2016 Ford Focus ST
I'm looking to finally purchase a set of wheels. I've always wanted to do a spare-tire delete but at the same time I see the value in a spare.
My question is: Are there alt-size spares I can purchase that I could store in my garage and bring along for the odd trail run or long trips?
I can't seem to find a steelie that are the same specs as the wheel I want to buy, 17x8.5 ET-10. I do plan on running a 285/70 tire.
Is there an alternate wheel / tire size combo I can run for my spare that would be good to run in the event of a flat?
PWillette
Parrie
Maine
There are most likely several different sizes that would work. Main concern would be to match the same diameter as the rest of the tires.
BeerForMyHorses
Nebraska
Ford Bronco 2-Door
Matching the tire diameter is the key. The width and offset are not relevant.
Probably a naive question, but if it's a spare in the traditional sense, how important is diameter? If you get something close but not exact, it's still good enough to get home or get to a shop, right?
I'm assuming diameter is important if it's intended to potentially be used off-roading
PWillette
Parrie
Maine
Correct, it doesn't need to match exactly but should be close, say within 1/2".
Silver-Bolt
Eureka, MT
The diameter is important on road or off. You do not want the tires rotating at different RPM. If your rig happens to have a limited slip diff the different sized tires can burn it up pretty quick. If you are off road and have lockers, that will cause issues as well. Spend the money and get a correctly sized tire. It is far cheaper than the repairs you would face if you don't.
BeerForMyHorses
Nebraska
Ford Bronco 2-Door
Almost all cars come with a donut that definitely is not the same diameter. But the purpose isn't to drive on it long. Just to get home/to a shop. That's why they say less than 50 miles?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Look for a Soft 8/D window steelie, most are around 0, I've seen -6, either will be close enough.
xiLLeNtz
Ontario, Canada
2016 Ford Focus ST
Seeing that my stock OBX setup would likely never sell.. LOL.. The tire setup I'm looking to change to is approximately 32.7" in diameter.
If I changed out the tire on my stock OBX to lets say.. 285/65 on an 18 vs 285/70 on an 17 are 32.6" vs 32.7" as per the tire size calculator on tiresize.com.
Obviously the wheel itself is a different size and different offset. Would this be suitable for a spare?
Tricky Dick
Dick
PNW
If I changed out the tire on my stock OBX to lets say.. 285/65 on an 18 and 285/70 on an 18 are 32.6" vs 32.7" as per the tire size calculator on tiresize.com.
It's close enough and would be fine.
Here's a 17x8 -6 like I was describing. https://viciousoffroad.com/products...-5-4-25bs-6mm-off-set-gloss-black-p-n-51-7883
