Question about 2 door seat
Hkak45
K
Illinois
21 Bronco Black Diamond
For the 2 door owners..... When you lift the lever on the top of the seat to pull the seat forward when getting into the rear seat, is there any way to get the seat to go back to the position it last was on the track when pushing the front seat back?
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
Yep. Just slide the seat bottom back first (goes back to the correct distance), then tip the seat back (locks in at the correct angle). This is the same way front seats in 2 door cars have mostly done it over the years.
Hkak45
Hkak45
K
Illinois
So you are saying with the seat back still tilted toward the dash, push the seat butt back and then tip up? Or do you have to pull the lever under the seat butt first?
F OR D
BD Green Machine
you literally just slide it back into position and then push the seat back up (folded down).
Scott R Nelson
Meridian, ID
I've had my Bronco since the end of January and it was only a few weeks ago that I learned about the release at the top of the seat. No mention of it in the owner's manual. Works much better than using the two levers. It's still difficult to get back there, though.
Most of the time you just slide the cushion back then push the seat back. Except that at least once mine wouldn't slide back except using the lever under the seat, so your mileage may vary.
Except for the 2005 Mustang. I could never understand why Ford couldn't make that seat work that way if VW could do it in the 2000 bug.
Hkak45
Hkak45
K
Illinois
Thanks for the replies. I'll try this method instead of normally pushing the seat back first
kodiakisland
Arkansas
Seat down, slide forward. Slide back, seat up.
