Pulsar XT concerns '23 2.7l
SHOtruck
TOM
Naples, FL & Rocky River, Ohio
15' Taurus SHO '23 Bronco 4dr
I installed the Pulsar XT in my 2023 Outer Banks 2 weeks ago. I like the extra power, auto-stop shutoff, tire size adjustment, and error code reader, but I have issues with error messages. I've tried disconnecting/reconnecting the battery, hooking the xt to it's own battery terminal, cancelling error codes through the device, and re-installing. These are the concerns:
Ford Bronco Pulsar XT concerns '23 2.7l dash
Ford Bronco Pulsar XT concerns '23 2.7l dash1
Ford Bronco Pulsar XT concerns '23 2.7l dash2
All error messages occur after the engine is running. I have to hit 'ok' to cancel each one individually.
Otherwise, the system works well adding power, but I am nervous about the red battery warning and wrench staying lit the whole time I'm driving.
SHOTRUCK
KABQ
Aaron
Albuquerque, NM
I have the Pulsar XT on my '22 2.7 and have never had this issue. I would first double check all your connections and make sure your battery is charged (lots of weird warnings if the battery voltage dips).
Can you share the DTCs it's showing? You should be able to pull them from the Pulsar app.
SHOtruck
SHOtruck
TOM
Thanks for your reply. There are no error codes. The '21 and '22 do not have these issues. Ford made revisions to the '23 and newer Broncos that forced Pulsar to turn off the battery monitoring system in order to cancel the auto-stop. I'm looking for '23 and newer owners who may have found a fix or work around.
SHOTRUCK
