Puddle Lights with Logos
OutlawOBX
99 F-150
Thanks, nothing but the lights in my box
I'd Email them and see if they could send you a tool. If you look up the video of the mustang you can see one of the two styles that I know of.
BadRobot1031
2023 Bronco
I tried emailing them the area where you type the message nothing show up
BadRobot1031
2023 Bronco
I ordered from the site thats was given on this forum
Aviator
Detroit
youtube.com
2023 Bronco Raptor
Same issue for my Raptor. The flares get in the way, and you have to rotate 90° to be perpendicular to the body. To have most of the image hit the ground. If parallel, the image hits the flare, as in the case of the OP. Passenger side works better. Needs an odd angle on the driver side to have most of the image hit ground. They need to angle the lens to point the image further out away from the vehicle for the Raptor.
Ford Bronco Puddle Lights with Logos IMG_7477
Ford Bronco Puddle Lights with Logos IMG_7476
jatt143
BRaptor, C63s, Defender 110
Installed mine and this is what they look like . Cant even read the wording on either one.
Were you able to fix yours? I'm getting half-chopped words like you no matter what is the orientation is. OP logo is throwing projection a little bit further away from the car, whereas ours is much closer.
DewarT
Todd
Mine worked fine on the Raptor- you have side specific lights and they require rotational adjustment.
jatt143
I'm sending messages to this guy and he is not responding. lets see if he can ship me correct ones too
