Problem with Mabett Mud Flap
BrianH
I was almost to the finish line when I was screwing in the 3rd bolt (the one on the inside and not on the bracket) and the screw is just spinning. There’s nothing there to secure the screw. Anyone run into this ? - thanks
Clemmy
Mustang MachE
Picture?
Picture?
RedSoloCup
Brock
NorCal
2024 Mustang GT
I just installed and i think you are talking about the whole where a pin goes not a screw.
RedSoloCup
Brock
NorCal
2024 Mustang GT
Where my finger is pointing is a plastic pin. Use the ones they supply the stock won’t be long enough.
Ford Bronco Problem with Mabett Mud Flap IMG_7907
Clemmy
Mustang MachE
Was thinking the same so thought a picture would help clarify!
RedSoloCup
Brock
NorCal
2024 Mustang GT
Thanks guys and it was operator error. A pin goes in that hole and it doesn’t fit very securely so I put a longer screw in the pin to secure it.
Yea the stock ones wouldn’t work. Luckily they supply 4 extras that are a tad bigger and longer i used
Mabett
Mabett
China
www.facebook.com
Bronco Black Diamond
Hi, I am Ryan. You can directly contact me for help.
BrianH
Thanks Ryan - I figured it out. I like the mud flaps but have you considered making a longer flap for the Sasquatch and larger tires? They look a little short and not sure how effective they will be from rocks being kicked up. I also ordered the seat back covers and cargo side protectors. - thanks
Mabett
Mabett
China
www.facebook.com
I am not sure. If we decide to make one, I will notify you.
51Creature
Kelly
New Brunswick
Ram 3500
Mine on drivers side is almost completely cracked in half. Had to zip tie it so guess I’ll see if any better ones available now. Not great for Canadian climate.
