Pre-Delivery Self-QC Checklist
texashoya
Austin, TX
BMW X5
Hey y'all: So now that the lucky among us are starting to take delivery and putting some miles on their rigs, it occurs to me that there have been a number of things that those of us who will be picking up trucks from the dealer in the coming months should be keeping an eye out for when our vehicles make it to the lot. In other words, a pre-delivery self-QC before signing the paperwork and driving off the lot.
I have a mental list going, but figure it might be good to crowdsource a bit. Here's what I have so far:
  • Unpainted parts: check tailgate, inside of gas door, inside edges of doors/hood
  • MIC exterior: check for gaps between panels, delamination at edges, seated seals, "honeycombing", mismatched panel color/texture.
  • MIC interior: Ensure all latches present. Ensure sound deadening installed.
  • Rear window strut: ensure firmly attached at both ends, no loose epoxy
  • Clamps & zip ties: check hoses, electrical cable bundles, HVAC ducts
  • Exterior paint: check for haze, swirls, chips
  • Hood: proper alignment at edges all along the length of hood, with no dips. Also check alignment from head-on.
  • Upholstery: color/material matches throughout
  • Fuse box: ensure 3x bolts tight
  • Body panels: aligned w/o gaps
  • Side Mirrors: no whistling at highway speeds (if so, dealer should replace mirror cover per Ford bulletin).
  • Windows: properly drop when door is opened—should not catch on roof seals.
  • MT Transmission: listen for unusual noise when shifting out of neutral (possible throw-out bearing issue).
  • Odometer: check for excessive mileage
  • Price Protection: see here (e.g. Base should get a certificate for $800)
  • FordPass points
Any others? My hope is to have a list I can print out and bring with me on that glorious day when I go to pick up my long-awaited truck.
Note: I've been critical of Ford on this forum from time to time, but this is not at all meant to be a gripe-fest. We obviously all like something about Ford, and LOVE a lot of things about the Bronco. Consider this a cooperative effort by us early adopters, the hardest-dying of the die-hard fans, to work with our dealers and FoMoCo to get out ahead of some of the growing pains that any innovative, brand-new vehicle would face (especially in a pandemic). So keep it positive, please. Also, hat tip to @bobbib for the inspiration and some list items :)
bobbib
Bobbi
Southern Illinois
Ford Ranger Raptor
@texashoya out here changing the world ;):ROFLMAO:. I can see myself making the checklist with pictures inserted from this forum. Not that I want to insult any dealerships and their ability to catch possible issues, BUT having pictures with arrows that indicate “please, if you see…..you need to fix it asap”
Anything else we are missing?
And thank you for starting this @texashoya !! @Headsong …..any specific one that you feel is all comprehensive?
feeble
Shawn
Yankton, SD
2022 Badlands, 1977 Cobra II Monroe Handler
Didn’t a couple people have an issue with a coolant hose clamp that wasn’t tightened up?
bobbib
Bobbi
Southern Illinois
Ford Ranger Raptor
Yes. Please post any pictures of this issue to this thread.
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Cable Guy
Kurt
Audi RS7
Ford Pass Rewards Points:
200,000 for MOD to MIC roof
11,000 User Appreciation Points
20,000 Early Reservation Holder
42,000 New Vehicle Purchase
1,100 converting before March 19th
Customer Satisfaction Funds: $1,000. Have your dealer go to the FDAD CLAIM PAGE on the Dealers Bronco Dashboard, if they dont know about it.
Bronco Swag Bag (first 100 Bronco orderer)
Items to check (based on Bronco6g OP feedback):
Pulley rub/ proximity next to radiator hose
Coolant hose clamp tight
Battery terminals tight (negative loose)
MIC Hardtop rough/sharp edges, gaps, leaks, roof rattles latches...especially seal in middle
Test all roof latches (some missing)
Check seat stitching and ensure seats match
Check seatbelt webbing for defects
Interior and trunk lights/bulbs work
Roll all windows up at once
Check window auto-drop
No license plate mounting (if mounting alternate location)
Owners Manual and Tool kit in glovebox
Tailgate hinge area and fuel door has paint issues
Any TSBs/ Service Alerts? A-pillar leak TSB: 21-2403
Paint bubbles/paint defects
Missing paint in door jambs/door brackets, tailgate, fuel door
Body panel alignment
Whistling mirrors
Sound deadening installed
Check underneath for corrosion
Check for transport damage
Check for rail dust (small specs of rust that will corrode). Must be clay barred off and repainted, or try iron/rust remover
Fluids all full (oil, washer, brake)
Confirm SEVEN Quarts of oil filled, not six. Ref:
https:///forum/threads/bronco-team-engineering-confirms-7-0-quarts-for-2-7l-engine-oil-change-is-correct.29047/
Full tank of gas (we paid for it!)
Door bags
Strut on back window unglued from hardtop (why not drilled in??)
Check all three bolts in the fuse box for looseness
Outstanding list. Thank you!
WuNgUn
Ontario Canada
2 door Squatched
Whistling mirrors
Door bags
Full tank of gas... Yeah right! I'll be sure to bring that one up. Lol
texashoya
texashoya
Austin, TX
BMW X5
Whistling mirrors
Door bags
Holy cow, here’s the whole list right here! HERO!
BroncoUT
UT
Whistling mirrors
Door bags
where did you get the info for all the fordpass rewards? I've only heard about the Mod Top and New Vehicle ones.
LadyBronco
Dani
Northern Michigan
Roller skates 🛼
Whistling mirrors
Door bags
Very detailed 💖 Thanks 🙏🏼
Monster1926
GMC Sierra 2500HD
Dent/dents on the hood. A few of us had their broncos delivered with them. I suspect it’s from the adhesive used in between the inner/outer hood. The pdr guy concurred.
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
Whistling mirrors
Door bags
This list is crazy, especially the $1,000 satisfaction funds. LOL I would bring popcorn and a lawn chair to watch a buyer go over this list with a dealer.
I took my first newborn baby home from the hospital knowing less than this list.
Maybe I am simple, I walked around mine, it looked good, I drove it home...1,200 miles later, no issues.
