Pre-Delivery Self-QC Checklist
Brandon1282
Brandon
U.P. of Michigan
2020 JLRD, 2021 GMC 1500 AT4 3.0
OWNER CHECKLIST for DELIVERY (OCD)
**Revision 1** 11/30/21
Ford Pass Rewards Points:
200,000 for MOD to MIC roof
11,000 User Appreciation Points
20,000 Early Reservation Holder
42,000 New Vehicle Purchase
1,100 converting before March 19th
Customer Satisfaction Funds: $1,000. Have your dealer go to the FDAD CLAIM PAGE on the Dealers Bronco Dashboard, if they dont know about it.
@Cat do you have anything to show where the 11,000 User Appreciation or 1,100 order conversion points come from? When I call the FordPass customer service number, they say they know nothing about it.
SigSauer226
James
NJ
1965 Ford Mustang Fastback, 2011 Ford Mustang G
Bronco Swag Bag (first 100 Bronco orderer)
Extended Warranty: Floodfordesp.com. 8 yrs 100,00 miles. $1600 to Flood for 8/100,000. $200 deductible. Can use Ford Pass Points (see FAQs.)
Items to check (based on Bronco6g OP feedback):
Pulley rub/ proximity next to radiator hose
Coolant hose clamp tight
Battery terminals tight (negative loose)
MIC Hardtop rough/sharp edges, gaps, leaks, roof rattles, popping from guide pins, latches...especially seal in middle
MIC panels all match in color, not two-tone
Soft top frame rubbing, seal alignment, fitment
Test all roof latches (some missing)
Check seat stitching and ensure seats match
Check seatbelt webbing for defects
Interior and trunk lights/bulbs work
Roll all windows up at once
Check window auto-drop for excessive snag/wobble
No license plate mounting (if mounting alternate location)
Owners Manual and Tool kit in glovebox
Tailgate hinge area and fuel door has paint issues
Any TSBs/ Service Alerts? A-pillar leak TSB: 21-2403
Paint bubbles/paint defects
Missing paint in door jambs/door brackets (may need to remove doors to see hinges in jambs), tailgate, fuel door
Body panel alignment
Hood dents on pax side caused by excessive panel bond on cross bars
Whistling mirrors
Sound deadening installed (hardliner)
Check underneath for corrosion
Check for transport damage
Check for rail dust (small specs of rust that will corrode). Must be clay barred off and repainted, or try iron/rust remover
Fluids all full (oil, washer, brake)
Confirm SEVEN Quarts of oil filled, not six. It's a 7 qt pan with a 6 qt dipstick. Ref:
https:///forum/threads/bronco-team-engineering-confirms-7-0-quarts-for-2-7l-engine-oil-change-is-correct.29047/
Full tank of gas (we paid for it!)
Door bags
Strut on back window unglued from hardtop (why not drilled in??)
Check all three bolts in the fuse box for looseness
Alternator belt installed backwards (smooth side against pulley)
Transfer case wire harness rubbing against drive shaft (missing plastic clamp)
Mismatched rollbars...holes drilled on one, but not the other
What is the 11,000 user appreciation points? I haven't heard of that one. How do we get it? I only got the 20,000 and 42,000 points.
Texas Sunshine
Suzann
North Georgia
Base Bronco
Whistling mirrors
Door bags
I copied this. Thanks!
  • Like
Reactions: Cat
Bird Dog Off Road
Jody
Phoenix, AZ
www.youtube.com
Cat
Cat
Whidbey Island, WA
MB500SL, HD Road King Custom
Points will be added to your account after you purchase, and after you sync Bronco with Ford Pass app. These are added by your dealer, not the Ford Pass folks. The list of Pass Points i compiled are points Bronco6g OPs have received. Check this link for more info: https://www.bronco6g.com/forum/thre...-reservation-holders.19679/page-4#post-948367
Cat
Cat
Whidbey Island, WA
Cat
Cat
Whidbey Island, WA
@Cat and OP, Thanks for pulling this together. I have converted this into a Google sheet and sorted/categorized these items. I will be using it today when I take delivery of my FE. I hope everyone is able to take advantage of this going forward. As more items appear, please add them to the appropriate category and keep this for future forum members/bronco owners.
Maybe a Mod and make this a sticky post.
GoogleSheet Link
Would love to hear back about how effective the OCD (Owner Checklist for Delivery) was, what you found, and the Dealer reaction when you used it.
SigSauer226
James
NJ
Brandon1282
Brandon
U.P. of Michigan
I’ve already taken delivery of my Bronco and when I called the FordPass Rewards customer service number, they had no idea what I was talking about with the 11,000 appreciation or the 1100 order conversion points. I’ve saved every email I got from Ford on the Bronco and I don’t see it there either. Do you mind sharing where you got this info?
BonzosBronco
B
Minnesota
15 Explorer, RIP 89 Bronco XLT, 2020 FTR
A couple questions/comments on this, Cat.
1- the 200,000 points were also MOD to Soft Top
2- How do we go about ensuring all of these points are activated to our Ford Pass Account? We are 7/14 reservation, 2/15 conversion, and had MOD top on our original order (changed to soft top in early July), so we should get all of those points.
3- What exactly is the User Appreciation Points and the Customer Satisfaction Funds?
Thanks!!
[/QUOTE]
Thanks for this excellent info and list - I was looking for something to use at pickup next week!
1 - Was there an end date for this switch from Mod to soft to receive points? @6SpeedBowtie
3 - I assume my sales guy doesn't know about or won't mention to me the Customer Satisfaction Funds. What's the best way to approach, "can I have the $1000 CSF please? I'll probably spend it here..."
Bronco Swag Bag - first 100 broncos at the individual dealership or the elite first 100 broncos overall? (love that swag)
6SpeedBowtie
Ken
WV/MD
Bronco, Wrangler, Corvette, Sierra, MGB
I believe the cut off was April 8, 2021
I believe it was extended, because when I made the change, I was told the offer was still on the table (and we changed in early July). The extension came when they announced MOD top wasn't going to be late 2021, but rather 2023.
6SpeedBowtie
Ken
WV/MD
Your pics blew me away. I included your issue & pics in a letter to the Ford Executive team this morning. I hope you don't mind...i prolly should have asked first? <cheeky smile>
I don't mind at all. I was just dumbfounded that it could escape the plant like that. The picture is a point of record, and I haven't been nasty about this, just factual and honest.
Also, @Cat, you can add windshield washer spray and front parking sensors to the list. I just went to wash my windshield while out on a quick drive, and I can hear the washer pumping, but no spray -- and before anyone asks, the reservoir is full of washer fluid.
I'm getting a sense that I may need to assemble a "hit list" for the dealer and book a week-long stay with their mechanic.
I guess this is what a warranty is for, but this isn't going to be cheap for Ford.
Problems happen when you assemble cars, and an occasional lemon emerges (I know this because I had a 2017 JK Wrangler that was bought back by Chrysler after 45 days in the shop with only 374 miles on the odometer). If it can happen with a product that had produced hundreds of thousands over nearly 10 years, it's certainly going to happen with a brand new product. The concerning thing is, the high number of quality issues -- including some blatantly ignored -- that we seem to be seeing.
  • Wow
Reactions: Cat
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Whistling mirrors
Door bags
Ensure all cameras work
The bronco satisfaction funds... Remind me who is eligible? Mine was built aug8-oct2nd(ish) and because I didn't get it timely I did complain and got free door bags out of it. I wonder if that's my "satisfaction funds." And what's concerning. If I didnt say anything I fear the dealer would have pocketed it.
