Potential new owner, looking for some advice
Beach_Bum
Ken
St. Augustine, FL
2023 Outerbanks Bronco
@Ape Factory Keep in mind that the MID package of a '22 Sasquatch BB is not the same MID package of a '25. You had said you built a number of orders via Build and Price in your initial post so you may be inclined to conflate the MID package on the currrent B&P as the same MID package on earlier model years. The biggest difference is that in earlier model years, the 12" screen was restricted to HIGH and LUX package with the 360 cameras. Early MID package Broncos received the 8" screen. Now, the 12" screen is standard across all trims. One still needs the HIGH package to get the 360 cameras, though.
Ape Factory
Ape Factory
Michel
Audi RS5/Ford F150/Infiniti QX70S
I found the original window sticker and it's a late 2023 build. December in fact. It's the base seven speaker stereo. Going to do a bit of research on upgrading that. I'd still like the high package but this has everything else I want and it's low miles, one owner. Has both tops, insulated, molded in color hard top, roof rails, Sasquatch package w/bead lock wheels, mid package, etc...no adaptive cruise, built-in garage opener or remote start. But I can live without those and add the remote.
On the suspension, the dealer info says Position-Sensitive Bilstein Shock Absorbers. I need to read up on the HOSS system to see exactly what it is but I thought it had Fox internal bypass components or something like that and they weren't Fox dampers from top to bottom.
Oh and the infotainment screen is 8" but you guys probably already knew that.
MNBigfoot
MN
Every auto Bronco can be started with a cell phone. Pretty sure auto start off the fob is on the mid package.
Ape Factory
Ape Factory
Michel
Well I think I finally found what I was looking for. Going all out with a Raptor which I looked at yesterday.
There were a few aftermarket components on it, including motorized running boards , alloy grab handles to bash your head on (I'm tall) and the fasteners that cinch the top down out back (not sure what the technical name is), all in Code Orange which is a cool contrast to the body color which is cactus gray. It also had an aftermarket blowoff valve (VTA) which gave me pause. Rest of the engine was 100% stock and it didn't look like it'd been wrenched on. I know how to spot these things of course and I did look over it carefully.
It's going to be blue certified so I'm obviously having them run a diagnostic to make sure it hasn't been tuned. I plan on going with a Ford extended warranty plan shortly so that's key.
I was also able to see it prior to being cleaned as it was a fresh trade in, locally owned, bought at same dealer. I saw how the original owner treated the car and it looks like it's been a pavement queen, interior was reasonably clean and there were no blemishes on any of the panels except for the rear cargo area which had a few scratches. A bit over 13K miles, I got an decent deal, not fantastic, but fair to me and to the dealer. Has all the options except for the graphics which I hate anyway. Wanted Code Orange but settled for Cactus Gray and I think I'll be pretty happy with that color long term and it should hide dust a bit better than the orange.
Pics after I pick it up later today, assuming everything goes smoothly and there are no hidden issues. They're going to let me take it home and make sure it fits in the garage first, LOL. I have a three car garage but I want to make sure I can get both the Raptor and the wife's SUV in there comfortably. I can drive my slightly lifted truck in and it clears and the two vehicles are almost identical in height so I should be good. We'll see about the width!
That's easy to revert back to stock if you don't like it, and it doesn't really affect the engine performance one way or the other. It mostly just makes pfft-woosh noises.
Ape Factory
Ape Factory
Michel
Yep, I actually have a high performance car business and I've been building track/race cars for more than 30 years including quite a few turbocharged cars. I was more worried that most individuals who install a BOV probably mod other things with a tune being the most obvious. Stock intake was intact and no tool marks on anything that I could see. Exhaust sounded stock but I didn't look. Was listening more intently to the engine itself to make sure the phasers were operating normally, LOL.
Kinda wondering if they'll swap the BOV back to stock in order to get the certification. We shall see. They needed a few hours to get it serviced today so I'm just waiting on the call to head over.
Ape Factory
Ape Factory
Michel
The off-road and removable top/doors functionalities are key features that separate Bronco from most other vehicles. I don't think you mentioned those as being your key reasons to buy, instead you are mainly interested in pavement commuting and safety? Simply from a rational functional use, I'd think about if it's the right vehicle for your usage.
Appearance wise the Sas package gets the bigger tires with more appropriate gearing, although the 10 speed auto trans seems capable of countering less than ideal diff gearing, especially if you find a non Sas with optional shorter diff gears.
For your off pavement use any Bronco should do, it's more about deciding on the desired tech/comfort/appearance items.
Agree with your assessment 100% and ability to remove doors/roof were definitely a reason why. I'm a former Jeep owner and gave it to my niece. While it will see plenty of pavement, we already have our first trip planned up to Glacier National Park in the summer and likely out to Big Bend here in Texas this winter. Being the last of the savage generations, we spend quite a bit of time outdoors.
Ended up going with a Raptor, should have it later today. Finally decided to go big or go home and I liked the interior (front seats really) far more than any other Bronco model. Hadn't really been looking at them until I started seeing the market signs and the rather large price drops.
Ape Factory
Ape Factory
Michel
Officially a member of team Bronco. Parked at work for the day job :)
Ford Bronco Potential new owner, looking for some advice IMG_7304
