Possible to remove the rear tailgate door completely?
Juicy
Jay
4Door Basesquatch, Corvette C7
Does anyone know if it's possible to remove the rear tailgate door completely? I know that its possible but how hard is it? the hinges look a bit complicated, would anyone care to share how its done? thanks
Ducati1098
501-03 Body Closures
2022 - 2023 Bronco
Removal and Installation
Procedure revision date: 01/4/2023
Tailgate
Special Tool(s) / General Equipment
Interior Trim Remover
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Remove the nuts and the spares wheel.
    Torque: 66 lb.ft (90 Nm)
Ford Bronco Possible to remove the rear tailgate door completely? video
Ford Bronco Possible to remove the rear tailgate door completely? Hel
  1. Open the tailgate.
  1. Release the clips and remove the loadspace scuff plate trim panel.
    Use the General Equipment: Interior Trim Remover
  1. Pull the rear edge of the load space trim panel enough to detach the tailgate wiring harness electrical connector.
  1. Disconnect the tailgate wiring harness electrical connector and detach the wiring retainers.
  1. Remove the fasteners and the tailgate hinge cover.
  1. Mark the location of the tailgate hinge to aid in installation.
  1. Remove the clip holding the tailgate strut and position aside.
  1. NOTE: This step requires the aid of another technician.
    Remove the bolts and the tailgate.
    Torque: 30 lb.ft (40 Nm)
  1. If required.
    Remove the bolts and the tailgate hinge.
    Torque: 22 lb.ft (30 Nm)
Installation
  1. To install, reverse the removal procedure.
  1. Align the tailgate as necessary.
    Refer to: Tailgate Alignment (501-03 Body Closures, General Procedures).
JFelty
Stroppe
Minnesota
Lincoln Corsair Hybrid (Plugin)
Stroppe
Ford Bronco Possible to remove the rear tailgate door completely? E305D6B1-F3BA-4BEC-B1F1-5BBF6DA8113C
But I would lose my sub 😧
Lifeliberty
Moonbeam👀
Columbus, OH
Is not hard at all. I had it off when installing my tailgate reinforcement... by mistake.
It's really only attached by the 4 hinge bolts, wiring harness, and the tailgate strut. Without the rear tire on it's like 30 lb
You will lose the reverse camera, spare tire, and third brake light.
I don't know if running without the wiring hooked up will throw codes.
Alignment would be my concern with reattach
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Florida man sawzalls off rear tailgate...would be a great thread title.
Juicy
Juicy
Jay
2022 - 2023 Bronco
Tailgate
Removal
NOTE:
  1. If required.
Installation
  2. Align the tailgate as necessary.
Thank you! i looked everywhere, where did you find this?
Charlieboy512
charles
Houston
Bronco sport
I took my tailgate off putting it back on was easy. The only thing is my gate is up by half an inch or so I’m just wondering if I can put the tire back on . I have the RC tailgate reinforcement it doesn’t make noise so I’m assuming it’s ok to put the tire back on
Ford Bronco Possible to remove the rear tailgate door completely? image
