Please, please buy 5...
Hossfire
Richmond, VA
'06 Jeep Commander
I have seen a couple Broncos around town where the owner upsized the wheels/tires but not the spare. Not only does this look comically stupid, but probably isn't safe to use as a spare.
JeebusCripes
Mn
‘94 M998, ‘89 Wrangler
This is a tale as old as time… ok maybe not that old but I recall my oldest cousin in the early 90s had an old CJ with four aftermarket wheels and a standard spare. Both of my old wranglers did too. Mostly because I just didn’t care. They were at least the same size as what I had on the vehicle. On my second wrangler I did finally buy upgrades and did all five.
VIRUS
D
Wisconsin
Truck, car, feet
I'm one of those guys.
I did buy 5 though. Taking a while to get the reinforcement I want. Every time I get a notification it's in stock, I'm busy and they're sold out instantly.
Thinking about saying F it and do a delete. Just leave the spare in the garage
AKBronc49
Russ
Anchorage, Alaska
I was just going to do 4 wheels for my winter setup (same 315/70R17) and use a cover, ran the cover a week and hated it. So I bought a 5th wheel and a used BFG for the spare. Just swapped my snow tires on tonight and the matching spare was the only way to do it.
DUSTYcazOREGON
Craig
Agreed. 5!
Ford Bronco Please, please buy 5... RearDone
MNBigfoot
MN
If the guy is buying 20" wheels, at least it looks good from on direction.
BroncoAZ
Mitch
In the event I need to use my spare (likely offroad) I do want a matching rim and tire. I agree with the OP that a stock non SAS rim and tire on the back with big tires and nicer wheels on the ground looks pretty dorky, at least run a cover.
I can’t leave the spare at home. If I got a flat I’d kick myself for turning a self sufficient issue into a tow truck necessary issue.
Squatch
Tires. The word you were looking for when you gave up and let a blind chimpanzee finish the title of this thread is tires. Ironically, it is as irksome as the four-tire mismatched miscreants you wish to call out with this thread.
DCtoobs42
Brad
1999 T4R Limited (RIP)
Correct if I'm wrong but doesn't doing 5 and incorporating that into your tire rotation get you 20 - 25% longer tread life? This is, off course, depending on how you like to do your math...
It also avoid dry rot on your spare, yes?
When I upgrade my tires, I will be doing all 5...
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
I agree to buy 5, but it's no more unsafe than every car on the road with a donut in their trunk.
Hell, there are cars that now come with a can of fix a flat,not even a donut. So they'll be fine, but it looks bad.
Newdoc
Greg
Central Texas
23 Wildtrak
If your diameter from spare to new size tire is off, you are asking for differential trouble. A few percent off maybe okay for a very limited distance.
Razorback
Dallas
Lincoln MKX
I'm not even thinking bout the spare for emergencies, I'm thinking the challange I would have on a tire rotation since I do a 5 tire rotation every 5k miles...
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
had a guy at work, lifted his Jeep and put 4 tires/wheels on. I gave him a hard time about the spare...so he just took it off entirely and looked even worse.
The guy I sold all 5 of my Goodyear's to, put them on his Jeep, but the spare won't actually fit on his tailgate. Apparently he needs a spacer. So he's driving around with no spare too. rofl
Felix808
SRV CA
What BS
If you're runnin 37's your spare 35 easily gets you to the tire shop
4 are plenty
Yep, very few vehicles use a full size spare. For off road, you should be no more than 2-3"s between sizes.
Similar threads
  • Locked
Replies
Views
2,053
Ignored member
Replies
Views
3,256
