Plastiwelding grille letters
Guardian1fox2
Jacob
Louisiana
2022 Bronco Black Diamond, 1923 Model T Racer
Does anyone know how to properly attach the grille letters to the grille itself? I got a new grille and letters, but from the factory it looks like they’re supposed to be melted in place…which is annoying considering they ship them separately. I wanna do it right instead of epoxy or whatnot. Just didn’t know if anyone knew if there was a tool or whatever that makes this process easy.
I was gonna call the Ford body shop today in town see if they do it.
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Yeah if your Ford dealer can do it for a reasonable price than I would do that.
flip
Phil
IN
www.ruxerparts.com
Fords
Not trying to plug my store but here's what we found works well and is reversible. The originals are likely sonic welded or they've got a special jig with a heated iron. These nuts are available aftermarket and likely a lot cheaper than OE.
https://www.ruxerparts.com/oem-parts/ford-emblem-nut-w707501s900?c=bD02Jm49Q2F0ZWdvcnkgUGFnZQ==
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
flip
Phil
IN
www.ruxerparts.com
Fords
Screw on like a nut and cut their own threads. I want to say they're for a 5mm post but don't want to swear to that.
flip
Phil
IN
www.ruxerparts.com
Fords
Found a pic online, you think it would just push onto the stakes and hold it in place?
They self thread when installing. If you look at the pic in the link, you can see a light thread cut into the post. They're called speed nuts.
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
Oh that’s awesome. I’m at work so I can’t tell what size the “stakes” are on the back of the letters. This would be an awesome find if it works cause I know people are just gluing them on etc.
flip
Phil
IN
www.ruxerparts.com
Fords
The nice part is you can take the letter on and off without destroying. Ford only sell them as a set so it could get expensive fast.
Cl1ckst3r
Joshua
Minneapolis
Ford Focus ST
I went back and forth on the "push on" emblem nut and plastic welding. I ended up buying a soldering kit on Amazon: https://www.amazon.com/dp/B07QNPFXX3
I then melted the stems to attach them to the grill and they seem solid. It's been through several car washes.
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
I’ll call my dealer today maybe I’ll get lucky and they’ll have some on the shelf. I think I’ll need 12 if it’s 2 per letter and if they’re $2 a piece $24 is worth being able to remove them to swap grilles or wrap letters or whatever! Guess I’ll be Guinea pig and report back!
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
I have a soldering iron but I’d wanna buy one cheap so I don’t ruin my good one. For the price I’ll try the nuts see if they work, worth a shot especially if they stay. I see other vehicles use them so I’m sure it would be fine as long as the stake is large enough
1970AMCAMX
Robert
Titusville, FL
F150, AMC AMX, DF Goblin
You should be able to get the "speed nuts" at any hardware store or auto parts store, just take one of the letters with you to match up correct size.
flip
Phil
IN
www.ruxerparts.com
Fords
The grill in the pic is one we did here for a customer and a suggestion from one of our older body guys. Worked out very well, IMO.
Guardian1fox2
Guardian1fox2
Jacob
Louisiana
Thanks man I’ll do that!
