- First Name
- Bryan
- Joined
- Aug 5, 2021
- Threads
- 41
- Messages
- 5,500
- Reaction score
- 14,632
- Location
- New England
- Vehicle(s)
- Ford Bronco, Escape, Focus
- Your Bronco Model
- Badlands
Yeah I think you would be happy with that.Ok got it, so if I’m using the OEM location, it will be easiest to do a two amp setup. I appreciate all the help, I think I have finally landed on my blueprint!
The ole ADD brain really took over on this brainstorm, but I think I finally herded all my mental cats into one pasture here.
When I first set out on this project, it was about creating a fuller, more high quality sound in the Bronco. Then I went all million dollar man wanting to go bigger, better, stronger, and ended up with all kinds of ideas. Finally, my illusions of grandeur wore off, and here’s what I’m thinking:
I have the 23, sub delete base system
I’m going to do the simple swap of the dummy amp and sub for the fusion amp and the Kicker 6.75” sub (4 ohms). This requires minimum effort but supplies me with bass and a fuller sound.
I’m still doing the SSV pods, and putting these audio frog 6” coax speakers in them https://www.crutchfield.com/p_898GS62/Audiofrog-GS62.html
For the front kick panels, I’m going with these Focal coax speakers https://www.crutchfield.com/p_091ACX165/Focal-ACX-165.html
And for the front dash location, I’m going with these audiofrog 4” coax https://www.crutchfield.com/p_898GS42/Audiofrog-GS42.html?tp=102
I know going components will probably lead to better sound, but in the interest of keeping it simple, I’m going with high quality coax.
Whenever I can find one, I will then add the kicker key 200.4 to power the speakers, and install that under the dash using the PnP kit. I’ve seen other videos where people install and hide the amp up there, again maintaining the hidden system.
Then wrap it all up with some ForScan wizardry courtesy of your sacred texts @RagnarKon to make sure everything operates properly.
In my mind, this setup gives me a drastically elevated system with little effort and minimal intrusion to the vehicle itself.
But my mind is not always to be trusted, so I’d love to hear opinions lol
Since the Kicker 200.4 seems to have disappeared from existence... it may be a good idea just to look at other options. The AudioControl ACM-4.300 is very similar to the Kicker 200.4 and should also also give you very good results.
@plugnplaykits also has a harness/kit available for the ACM-4.300. I do not know if the ACM-4.300 will fit in the same mounting location that everyone is putting the kicker amplifier (under the steering wheel), but if not... @Mountains2Metal has an amplifier mount available to mount amps behind the glove box.
