Passenger mirror light stopped working
Inlinejohn
WA
Several
Any thoughts as to why all of a sudden my passenger side Oracle Mirror ditch lights stopped working? Can’t be a fuse as the driver side is fine. Thoughts??
PWillette
Parrie
Maine
Have checked the ground and put a tester on the wiring? As you said, if the fuse is good it should be seeing power. If ground is good and you're seeing power on the positive side the ditch light probably toast.
OracleLights
New Orleans, LA
www.oraclelights.com
Other than checking all of the wiring and making sure nothing has come disconnected, please take a moment to fill out our online tech support request here: https://www.oraclelights.com/pages/tech-support-form and someone from our technical department will be in contact with you shortly. Thank you!
