NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS
OracleLights
New Orleans, LA
www.oraclelights.com
2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHT is the innovative new product from ORACLE Lighting features a set of high powered LED light bars integrated into factory-style side mirrors of the new Ford Bronco! This integration allows for easy installation and a sophisticated, almost "OEM" appearance while providing functional peripheral illumination for the driver. The LEDs are custom design that features a total of 24 LEDs producing approximately 2250 Lm. Each unit has a 45° beam angle to optimize the driver's peripheral visibility.
Product Features:
• Designed and Engineered in the USA
• 24x 1 Watt Cree LEDs
• 2200lm total output
• 45 Degree LED Beam Angle
• Advanced LED optics
• Modular Components
• 2 Year Warranty
• 6000K Color temp
• 2 Amp Power Draw
• Patent Pending Design
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS 5894-001_A_1024x1024
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS 5894-001_B_1024x1024
Functionality:
Why is peripheral illumination important? Factory headlights and most auxiliary lights only illuminate the area in front of the vehicle. Ideally for off-road activities, such as trail riding, the driver needs to be able to clearly see the area on the sides of the trail to spot obstructions, which would otherwise go unnoticed and could be a potential hazard.
Unlike existing "Ditch-Lights" which look like an afterthought the Side-mirror is the only part of the vehicle designed to be in the driver field of vision wheel driving- this makes it an ideal location to mount effective and functional lighting to enhance driver visibility during night-time trail rides. The driver needs to be able to clearly see the area on both of the sides of the trail to spot obstructions, which could go unnoticed and be a potential hazard.
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS bronco_led_mirrors_1024x1024
Innovation:
Besides being functional these new LED Mirrors from ORACLE Lighting look great as well! The LED light bar is a custom design that features a total of 24 powerful Cree LEDs. This gives the driver increased visibility and peripheral illumination. Each unit has a 45° beam angle to optimize the driver's peripheral visibility for riding on the trail or in the desert. Multiple aluminum heat sinks are used to effectively wick heat away from the LEDs and are designed to use the airflow through the mirror housing to increase cooling similar to a radiator.
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS Jeep_JK_LED_Side_Mirrors_1024x1024-2_1024x1024
Compatibility:
The Bronco trim levels have different features implemented into the side mirrors from the factory such as cameras, puddle lights, and indicators. To make these mirrors compatible with all trim levels blank plates were designed to replace these features on the ORACLE mirrors. If your Bronco is equipped with these features simple remove the blank and swap over the component. If you do not have these features just leave the blanks in place for a seamless appearance.
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS Bronco_LED_Mirror_Exploded_AM_1024x1024
Design:
Our goal developing this product was to create a LED light bar that could be seamlessly integrated into the vehicle design in a way the appears to be factory. Light bars tacked to bumpers and roof racks have poor integration and appear to be an afterthought. These mirrors provide a functional purpose and look good doing it- the best of both worlds!
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS ORACLE_Bronco_Hero_Shot_Small_ac7fff72-6ffa-44d5-a015-6778da9c16c3_1024x1024
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS 1628862392307 (1)
We are offering an exclusive pre-order discount on the 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS on the Bronco Forums exclusively for the first 100 units. This discount will not last long so grab yours now if you want in! It's easy to get in on this:
  1. Visit the product page for more information and resources.
  2. In the checkout section, add the discount code exactly as you see here> BRONCODITCHLIGHT
  3. This will apply 15% off the retail price listed. No other codes are applicable with this product. Free domestic shipping is applicable for this product.
Screenshot below of checkout:
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS Code.PNG
GET YOUR SPOT NOW!
Normal Price:419.95
Group Buy Price: $356.96
Free domestic shipping, international shipping is calculated at checkout.
Please note that the initial estimated ship date is currently January 2023 and is subject to change with notice.
Group buy code active for until the first 100 units are sold. Tentative ship date is said date and is subject to change. Must enter code for group buy discount. Only these lights eligible for discount, not applicable for other products. No additional offers are eligible for this group buy.
EL Señor Bronco
Miami, FL
2019 Hyundai Veloster N PP
Done! Looking forward to installing this on the Bronco!
Tex
Cliff
San Angelo
Nice, made it to the preorder. Hopefully these will reduce glare on the hood compared to the usual A-pillar mounted ditch lights.
F OR D
BD Green Machine
In, thoughts on adding a puddle light for trims that don't have it? Seeing you just basically made a housing for a future product...
RickDeckard
Wisconsin
Done
Tex
Cliff
San Angelo
You could order those lights from Ford, and while you've got the mirror taken apart it should be a straightforward install, then you could wire them to whatever circuit you'd like. I've actually considered wiring my zone lights or whatever they're called direct to a switch, since Ford made them shut off at 8mph they're pretty useless to me, so I may just put them on the same circuit as these instead.
CliffCo
Cliff
Charlotte
2021 Iconic Silver, Big Bend Sasquatch (MIC top)
DONE
Link1016
Ridgecrest, California
2022 Ford Bronco Badland & 2017 Ford F250
Done as well, but I forgot to use the right discount code. Wonder if the good folks at Oracle can fix it for me. Got excited and didn't follow the instructions.
CliffCo
Cliff
Charlotte
...can I just say that I'm SOOO friggun excited for these?!?!
