Parts Available for Engine Block Heater Recall/TSB?
rcl4668
Pacific NW
2019 Mustang Bullitt, 2023 Bronco Heritage Edition
Just checking in: I have a 2023 Heritage that has an engine block heater that is subject to the recall/TSB. Does anyone know if parts are available for this yet? I have not received a notice yet from Ford that parts are available. Thanks!
Ducati1098
Yes. Parts have been available for a while now.
Ducati1098
Just so you know, if you didn’t already, the recall is just simply going to remove your block heater.
Later down the road, Ford will release a customer satisfaction program to then fix and reinstall a block heater.
rcl4668
rcl4668
Pacific NW
Yes, I received that letter, thanks! I think the other alternative was to keep the block heater, not use it and then wait until replacement parts were available. I have thus far not received a letter from Ford saying replacement parts were available but a poster above stated that the parts were in fact available. I would prefer the latter option.
Ducati1098
The replacement block heater isn’t available yet. That will come later.
As of right now, only the parts for the recall interim repair to remove the block heater are available.
The recall is to remove the block heater, the customer satisfaction program that will be released at a later date is to replace the block heater that was removed.
rcl4668
rcl4668
Pacific NW
Thanks! I'll just wait until I get the letter from Ford that the replacement part is available.
Epiphany
Upstate
'24 Bronco
I have this on my '24 Braptor. Looking at the hardware I'm curious, if you know, what is faulty? The heating element that threads into the block or the harness? Or Both?
Ford Bronco Parts Available for Engine Block Heater Recall/TSB? Captureppo
Ford Bronco Parts Available for Engine Block Heater Recall/TSB? Captureppppo
Ford Bronco Parts Available for Engine Block Heater Recall/TSB? Captureppppoppppo
Ford Bronco Parts Available for Engine Block Heater Recall/TSB? Capturepo
Ford Bronco Parts Available for Engine Block Heater Recall/TSB? Capturepoo
Ducati1098
You shouldn’t have the recall for a Braptor. This recall is only for 2.3 equipped Broncos.
It’s for the actual heating element though. The original cord will be reused once the new element is available.
