Park Aid Fault
Weissmanjs
Josh
2022 WildTrak
Hi Friends - recently changed out my rear bumper, and am now receiving a park aid fault on the display behind the steering wheel and the error message attached. Any ideas and troubleshooting suggestions?
Ford Bronco Park Aid Fault A98E37DF-AED1-4EE5-A6DC-5A232F63A6A0
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
Did you hook the harness back up? Mine did that when I forgot to reconnect the harness on the 3rd time I took my bumper off.
Weissmanjs
Weissmanjs
Josh
2022 WildTrak
I did. Seem to all be installed correctly.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there, I'd be happy to look into your Bronco concerns on my end. Will you send us a message with your VIN and dealership info? I can look into things on my end.
mike8675309
Minnesota
Have you tried to disconnect the battery to reset the whole system?
Skanderbeg
Everglades
Rav4
Everglades
I have the same issue. The problem with mine is the oseal in the wiring harness is stretched out, so it's not letting it fully connect.
mandyhoth
Mandy
Explore
Have you figured out what caused this? Mine has started doing it since yesterday. I’ve taken it to the car wash twice and disconnected the battery for a bit but it’s still happening. I still have stock bumpers so nothing has been messed with on that end.
Weissmanjs
Weissmanjs
Josh
2022 WildTrak
Big DUH moment.
Big DUH moment. Plugged the license plate plug into the sensor. Why would Ford make the light connection and sensor connection the same!?! 😂. Resolved. Thanks for all the tips!
Benoack
Brandon
Allen, TX (DFW Area)
Ordered May '21 Badlands Sasquatch hard top, lux,
I just ran into this problem today. I put on a hitch receiver, now I noticed after clipping the two connections parking aid failure happens. Has anyone else had an issue like this? One thing I noticed is that the connectors don't snap back in. I've inspected the connectors. Can't see anything, but it is clear it's not fully seated
Brent
Kansas City
2020 F-150
I’m having the same issue. When I try to reconnect, they aren’t snapping back info place.​
Benoack
Brandon
On a FB group, someone just suggested to spray a little WD-40 into the connector. He noted the seal may have got dry. I did it this morning and it worked.
1MtnBronco
Tom
Forest Falls, Ca.
2022 Bronco, 4dr, Sasquatch Package
Same issue, removed/reinstalled OEM bumper only to get the Parking Aid Fault signal... tried the WD40 suggestion and bingo, everything back to normal.
c130ldmstr
Arkansas
2023 Bronco Raptor & 2012 F-150 Raptor
Big DUH moment.
Thanks for posting this! I had the same issue after installing ADD Bomber bumpers! Saved me from pulling bumpers!
Mark Borgmann
St Louis MO
2022 Bronco
Big DUH moment.
Thanks for posting the mistake because I did the same thing and it was driving me crazy! Once I looked I noticed the 2 wires only to one of the connections. I can’t believe there the exact same connector.
Jpinnella
Bronco Wildtrak
So simple and should not have needed to do this, but WD-40 did the job!!!! Thx!!🙏
