Outer Banks - Delete Tube Steps?
Bacon
CT
4 Dr IS MIC Outer Banks
Outer Banks would be perfect for me as it already includes Mid and LED Lights, especially since I can't get Manual w Mid on Big Bend. Can't get past the included Tube steps though, would be a deal breaker I think. Looks like I won't be able to do a tube step delete thru factory, so how easy are they to remove. Socket set will take care of this? Will any brackets be exposed after removing?
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
There are no brackets left behind. The steps are bolted on. Get your socket set out and crank away.
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
It's simply bolted into the body, its likely 2 brackets with a few bolts, probably torx knowing modern ford.
Desert_6G
Phoenix, AZ
Ranger
You can do a tube step delete by adding the rock rails.
Bacon
Bacon
CT
I did do this on B&P thinking the same thing, I'm sure its a mistake but the image in B&P shows the tube steps and rock rails.... hopefully thats a solution though! anyone else know?
anyone good w photoshop that can take tube steps off so I can see what OBX looks like without them?
thanks
TalexBrizzley
Alex
Southern California
Model 3, Silverado
thanks
I am definitely not good with photoshop but with the iPhone markup tool I did okay here. I'm on the fence between BD and OBX but if I were to go with OBX, I agree that the tube steps are the first thing to come off.
Ford Bronco Outer Banks - Delete Tube Steps? IMG-0992
If you'd like me to try this with a different color/configuration that looks more like yours, let me know.
marjen
CT
I see you are in CT? I am getting either a badlands or Black Diamond which comes with the rock rails. I would much rather have the tube step, maybe we could trade? I am getting a 2 door though not sure about you?
Bacon
Bacon
CT
a 4 door most likely, but never know... if I panic about price it can be an option... will let you know
Bacon
Bacon
CT
thanks! looks good without. area 51 4 dr is probably the one I'm going with
BuiltTough
F 150
liking the OBX without tube steps... makes it look tougher while still having all the interior options
was thinking Big Bend with mid, Auto Trans, V6, LED signature lights, and by the time I do this I'm very close to OBX anyway.. with OBX you have optional advanced 4wd which I would like.. If I go with OBX the tube steps have to go... can anyone photoshop a Race Red and Velocity Blue OBX without tube steps. Appreciate!
MikeyFrog
Iowa
I have little kids so the tube steps are welcome for now... As they get older may end up swapping to rock rails for that clean look.
BEM-S4
Philadelphia
BMWs & Porsches
Would be happy to trade you my rock rails for your tube steps...
Rivers90
Ben
Southern California
2 Door Base Sasquatch
I've pulled off tube steps from other vehicles in less than 10 minutes. Very easy.
BigBronco1
Mamaroneck, NY
2018 Silverado, 2021 XC90
I'll trade you the rock rails from my Black Diamond for your tube steps!
