ORACLE LIGHTING: DUAL FUNCTION AMBER/WHITE REVERSE LED MODULES FOR FORD BRONCO FLUSH TAIL LIGHTS
OracleLights
New Orleans, LA
www.oraclelights.com
Want to add an Amber Turn Signal to your ORACLE Lighting Bronco Taillights? These new modules allow you to do just that.
Ford Bronco ORACLE LIGHTING: DUAL FUNCTION AMBER/WHITE REVERSE LED MODULES FOR FORD BRONCO FLUSH TAIL LIGHTS 52885009588_1c5fc93648_o
The reverse light still functions like before with the same brightness but now also has an Amber feature for a bright turn signal in replace of the Red Taillight section flashing.
Ford Bronco ORACLE LIGHTING: DUAL FUNCTION AMBER/WHITE REVERSE LED MODULES FOR FORD BRONCO FLUSH TAIL LIGHTS 52883987307_92ca921fd4_o
Installs by removing the original modules and installing the new modules with the existing hardware. Wiring connects to the existing connector and a pin is added to original plug.
Ford Bronco ORACLE LIGHTING: DUAL FUNCTION AMBER/WHITE REVERSE LED MODULES FOR FORD BRONCO FLUSH TAIL LIGHTS 52885009533_ba275dfb6d_o
techdisaster
Not a Bronco
I got my shipping notice for my tail lights and amber inserts today. Forscan is sitting on my bar, ready to go. Hopefully I can install these ASAP and fix my broken tail light.
techdisaster
Not a Bronco
I finished installing today and it almost went perfectly. Can I suggest that you put the updated forscan instructions somewhere? Nowhere during the install process or videos was it clear that there were different forscan instructions. I found reference to them in another thread, and wrote combined instructions for with and without:
BRONCO FORSCAN SETTINGS FOR ORACLE FLUSH MOUNT TAIL LIGHTS – LED REPLACEMENTS
You will need to use FORSCAN to update the BdyCM (Body Control Module) settings if you have the Signature LED tail lights. There are two different procedures, one without the Amber drop-ins and one with the Amber drop-ins.
For Oracle Tail Lights Without Amber Drop Ins:
FunctionOriginal ValueNew Value
Left Rear Stop and Position Lamp UsageNot UsedStop and Turn
Left Rear Turn Lamp UsageStop and TurnNot Used
Right Rear Stop and Position Lamp UsageNot UsedStop and Turn
Right Rear Turn Lamp UsageStop and TurnNot Used
Rear LED Turn OutageEnabledDisabled
For Oracle Tail Lights With Amber Drop Ins:
FORscan does still need to be used when installing - However just to only the Rear LED Turn Outage setting to avoid rapid flashing indicator. No other settings should be changed.
NOTE: If you have upgraded the reverse light modules in your existing Flush Tail Lamps & you have already made changes in FORscan, you should revert all settings excluding "Rear LED Turn Outage" to factory original values above.
GI_Jo_Nathan
Jonathan
So just to be clear. Will these work on Bronco's that originally had the base halogens?
GI_Jo_Nathan
Jonathan
No. The halogen lights do not have the same wiring harness necessary to run the Amber inserts.
That's what I figured, wasn't sure if the Oracles had some magic going it.
Thanks.
Edit: I guess I could have clicked the link earlier.. 😂
"Fitment: This will only work for Bronco models with the factory LED tail lights."
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
How much brighter are these reverse lights than stock LED's?
OnyxBronc
MWest
1. Are these going to become a regular option with the flush tail light purchase instead of a separate purchase?
2. Any Memorial Day discount sale? I'd like to purchase a new headlight set; not interested in free footwell/interior lighting.
Thanks!
Bikeric
Tulsa
2022 Badlands LUX on 37's
What if I want to use my turn signal while Reversing???
