Option to turn front camera on when using Park Assist?
Bklewis77
Brandon
Dallas
2021 F-150 Limited Powerboost
Does anyone know if the front camera turning on when using park assist is an option on the Bronco? The front camera in my F-150 automatically comes on when inching too close to something while pulling forward. I notice on the Bronco even with the same cameras, it does not come on. Just curious.
Strangely, the camera on my F-150 does not automatically turn on when put in mud and ruts mode, but it does on the Bronco.
Ford Bronco Option to turn front camera on when using Park Assist? 20211111_135442
RagnarKon
Ford Bronco, Escape, Focus
If you are talking about the Ford Co-Pilot360 Active Park Assist feature that is available on the upper trim F-150s... that's not available in the Bronco at all.
Here is what you do get:
  • Rear backup camera (all trims, required by law)
  • Rear parking sensors (Mid package and up)
  • Front parking sensors (High package and up)
MysteryCamper
TX
2021 Bronco FE, 2000 Jeep Grand Cherokee
Unless there's a software setting somewhere that Forscan can access there is no option to automatically turn the front camera on based on the parking sensors.
Best option is to push the camera button while parking to manually turn the cameras on.
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 23 Bronco
Where is that camera button? I have looked all over for how to activate the front camera when I am parking, and all I have been doing is popping it into "R" to see the over head view.
one800higgins
VW GTI
There’s a camera button?
Being able to manually enable the 360 cameras while parking in tight quarters would def be nice. My solution is just to leave the trailer assist feature on, which keeps the cameras rolling until like 12 mph or something. Of course then you have to trigger the cameras via reversing or starting the car.
MysteryCamper
TX
Assuming you have the camera package, it's here:
Ford Bronco Option to turn front camera on when using Park Assist? 20211118_085051
tobands
2022 Bronco OBX , 2024 Edge ST
KyTruckPlant
Goshen, Ky
If it had been a snake it would have bit me. I've looked right past it a hundred times now. Thanks!
Derkz34
William
2022 Bronco Wildtrak, 2024 Livewire S2DM
Anyone know if you can adjust the speed for when you can turn on the manual front/360 camera? I love the functionality and it makes for a perfect park every time, but because the pulling in speeds are too fast for it to activate It wont work and by the time the error goes away and I'm at speed I'm already 3/4th parked
‘21OBX
90Bronco19
2022 bronco outer banks
I’m hoping someone can figure this out. I’ve tried a lot on forscan but can’t get it to come on faster than 6-7 mph.
