- Jul 14, 2020
- 125
- 6,173
- 7,129
- California
- Jeep Wrangler JKUR
- Wildtrak
Winches draw so much power and can't see using one without the vehicle running. As long as you wire it up correctly the factory battery will work just fine...at least it does on mine.Thank you for all the great replies/info. The yellow optima is a direct replacement and my concern is that if/when I add a winch, the extra load would need more than the OEM battery. If this is not the case, then making a change now is not needed...
