Opinion on how these Infinity Reference speakers sound?
j_marinelli
Spring Branch, TX.
I have these in mine and so far I'm happy with them over the stock units. I think they are a great bang for buck speaker.
Down the road might do an amp for them and explore a small powered sub to add a little bump.
jaspercasidino
PNW
2022 Bronco
@BudgetBronco did an install and sound comparison video. I have also ordered a set of these speakers for the dash and rear and will install this weekend or next week.
Here is a link to the video:
fitterhappier
Adam
Round Rock TX
2022 Ford Bronco
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Yep - putting in the Kenwood under-seat sub as well.
Have you measured under the seat? I fit my amp and crossover in, but it is tight. I measured and looked at a couple of under seat sub options, but nothing I came up with would fit.
fitterhappier
Adam
Round Rock TX
2022 Ford Bronco
The Kenwood will fit but I have to tamp down the vent. There are a few subs that will fit though. I think someone on here got one of the small Pioneer subs in there without issue.
Brock9281
Brock9281
Rob
Atlanta
I’d like to know as well. I think the downfiring Kenwood sub might best for rear
Mattwings
Matthew
Northville, MI
Got it, I’m not willing to eliminate the vents. I think I will try a custom cabinet in the rear roll bar triangle first. Seems pretty straightforward to mount with the top bolts and rear spear pod mounts to use to secure it and make it easy to remove for the once or twice I take the rear top off 🤞🏽
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Somebody above linked my video and I hope you find it helpful. I think on this topic, like a lot of things, you will find that you can make nice improvements for a small investment, and then you get some diminishing returns as you continue to invest. We can all agree the base 6 speaker system is pretty bad, let's call that a 3/10. For a $150 investment you can take that to a 6.5/10 just by adding four 4" speakers with a couple of bass blockers and some dynamat. And if you want to keep spending take it to an 8 with an amp, and 9 with a subwoofer, etc but now you have invested probably $800 or more.
There was a really good post a couple of days ago saying they got it to 15/10 with a $1000 investment, but that was over the B&O system that already carries with it some additional investment.
Brock9281
Brock9281
Rob
Atlanta
In your opinion, do you think you’ll get better results with 6 new speakers + amp ( no sub) OR 4 new speakers + powered sub (no amp)?
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Sorry but any answer I give would be just a guess. I am sure somebody here with more knowledge like @Ksjrb03 can give a better answer
Mattwings
Matthew
Northville, MI
OK, I just finished the swap of the Infinity Reference 4" with the Kicker KSC-40s. They are not quite as loud as the Infinity, as would be expected by the sensitivity rating (also slight lower 3.2ohm nominal impedance). The Kickers do seem to have a slightly better sound stage and the tweeters do not seem as bright to me. They also handle the lower frequencies/higher volume (with amp) slightly better, but not enough change to eliminate the need for supplemental bass. Overall the difference is pretty minor. I would suggest the Infinity for sure without an amp. I will be moving those to the rear pods once I get a replacement speaker from Harman/JBL. Hope that helps some trying to decide on speakers.
j_marinelli
Spring Branch, TX.
Just curious if anyone has heard the JBL vs Infinity speakers? I have wondered if the JBLs are as bright as Infinity since they are both Harman companies or if they sound noticeably different.
Brock9281
Brock9281
Rob
Atlanta
I’m just concerned the Infinity will be too bright we’re I’m wanting warm
Johnny Mo
Westchester County, NY
teachu2shoot.com
M-B GLE53 AMG, Ducati XDiavel, Jeep WK GC x3
I went with the newer version of these Infinity Reference speakers the 407f. Also upgraded my Sub and added the Kicker Key 500.1 to drive it. It was really good but like others mentioned a bit bright. I saw that someone had replace the kick panel speakers with a pair of Memphis MJP6 speakers 100db efficiency so I was thinking I could get away with no amp. It worked to provide the fill the front stage needed. Absolutely thrilled with the new setup and I spent right around $1100 all in.
redvettx2
Tom
Scottsdale, AZ
05 Maserati Coupe GT,16 Jag F-Type S,65 Cobra 427
7 Speaker system here with factory sub-woofer. Just switched out the 4" speaker for Infinity with no base blockers and no Amp. Very happy with the sound and performance.
