Status
Not open for further replies.
HammerNQuill
Ben
Brooklyn, NY
2012 Nissan NV 2500, 2023 RAM ProMaster 3500
I had an itch to work on designing something a little more versatile... I present the Modular Cargo Platform (MCP)
Using 10 series extrusion as a frame, this will increase rigidity and platform security. Additionally, horizontal T-slot tracks run the width of the cargo area to provide flexible mounting points for tie down anchors, fridge slides, leveling platform, or whatever you can imagine. Large panel access to the cargo storage areas is maintained, with split access for the larger one (in case something is mounted on one side or the other).
This is still just a concept. I've got other priorities at the moment, but hoping to build something like this soon.
Nicely done! I like the t-track for keeping things from sliding back and forth; lateral movement can be limited more easily. Just include relief openings for sliding in T-bolts and this is a great start.
Russ.Cere
Russ.Cere
Russ
modcrate.myshopify.com
Made a few brackets for the trunk. These should arrive late this week for proofing.
Edit* These will be added to the DIY Section of Modcrate
Ford Bronco Open-Source: Trunk Storage System (Open TSS) 88598243-e587-44e2-9ea6-a848448e5fe8
Ford Bronco Open-Source: Trunk Storage System (Open TSS) ab04d493-8d6f-4935-80c8-36ebc3345147
Ford Bronco Open-Source: Trunk Storage System (Open TSS) Single_Floor_Side_mount_2024-Mar-19_06-12-29PM-000_CustomizedView72195863295
Russ.Cere
Russ.Cere
Russ
Working on a base update. I hope to have to new base files uploaded and available by COB Friday.
As pictured will require use of a manual or CNC router.
Center removable panel drawn with 1/8 saw kerf
Ford Bronco Open-Source: Trunk Storage System (Open TSS) OTSS Update 25MAR24
Ford Bronco Open-Source: Trunk Storage System (Open TSS) Plywood_Cargo_Quick_Slide_version_2024-Mar-25_09-41-48PM-000_CustomizedView4188523275
Ford Bronco Open-Source: Trunk Storage System (Open TSS) Plywood Cargo Quick Slide version v6 BV
Russ.Cere
Russ.Cere
Russ
Apologies to anyone watching this thread. I received my military orders and am planning a cross country move. Update attached.
Consider checking out Bronco Mods – ModCrate purchases support my DIY projects.
If you have your own cnc router and need 3d files message me and ill sort you out.
*EDIT: Pocket detail dimensions to come later today.
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
does anyone have the dimensions/measurements to where the bolts would go in the corners to tie the platform down?
Russ.Cere
Russ.Cere
Russ
I'll add that later today, see edit on previous post.
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
I have an approximate model based on the 4 door's cargo area dimensions and applying the measurements found here.
do you have the measurements for this design? 4dr
Darcyjs14
D’Arcy
Seattle
1970 Ford F250 Camper Special 4spd
Hey @Russ.Cere, n00b question here. Could I send this out to Send/Cut/Send for fabrication? I have a fabricator that I work with too. He’s got a waterjet, so that might be an option for me too.
Russ.Cere
Russ.Cere
Russ
You can. They only offer ~.5" thickness for routing, I think that's a bit thin. I also think their pricing for large items like this is a bit on the expensive side. What I did was search Facebook market for someone offering CNC routing services cost me about $90. You're in Seattle? Sunday I can dig through my Facebook messages and put you in touch with the person I used.
Could hand route as well. .
Darcyjs14
D’Arcy
Seattle
Lakewood, by JBLM. My kids live on Mercer Island, so I’m up in Seattle all the time. It would great if you’re will to share your fabricator.
Russ.Cere
Russ.Cere
Russ
mpeugeot
Awesome stuff, bookmarking it for future use.
Russ.Cere
Russ.Cere
Russ
I still recommend shopping around I find a good number of freelancers that do great work.
mpeugeot
I am stealing ideas, not looking for a contractor. ;)
Status
