Ooo I messed up lol
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
Went to change my tire size since I recently upgraded. I’ve done it twice before no issues. And our Broncos. Well this time I did something and got a pcm/exam no vin programmed error. 🤦. I had my backup files and got everything sorted but somehow killed my keypad the stick on one. I know it was added after the as built. If forscan can take it out can it be put back with forscan? I couldn’t find a way when I bought it and had to have a friend that works at ford ad it.
‘21OBX
‘21OBX
Ken
90Bronco19
SCBronco1
Peter
2019 F150 Lariat Fx4, 2012 BMW X3, 2011 Escape
If you had it added at the dealer verses the body color painted version that is now available then there might be hope for you. Those keypads work like a key fob and you just need to program it like you would an old school key fob. This guy walks you thru step by step on his Ford RV. Its one of the best videos I could find on the subject. MAKE SURE THAT YOU HAVE BOTH REMOTES WITH YOU WHEN YOU DO THIS! I hope that this helps.
‘21OBX
‘21OBX
Ken
90Bronco19
Good luck with that!! That does not work on the Bronco. At least I couldn’t get it too. Maybe I’ll revisit the as built site. It was done through FDRS in fords system so maybe it will have a updated version. Worth a shot.
SCBronco1
Peter
Hope that it works for you! Call your salesman, maybe they could suggest a solution.
