Ole Blue - Build
Danielsand
Daniel
Idaho
'21 OBX SAS
Definitely left out some HP dust. 😂
But the color is spot on.
Now THIS has it all! The length, the girth, the prowess, .....OMG! If it would be Erection Green, I would just drop dead under my desk now.
AZCoyote
AZCoyote
Wiley
Phoenix
2024 Big Bend Sasquatch
Pfffffftt…. Bwwaaahaahaa!!
YellaHEL940
Brandon
Indianapolis
2023 VelociRaptor
Very girthy she is. Darn it. That was my other choice. But it didn’t have code Orange and the wife had to have the seat belts. 😂
AZCoyote
AZCoyote
Wiley
Phoenix
Fixed the quarter panel emblems.
patch moved to door for fun.
Ford Bronco Ole Blue - Build IMG_2318
Ford Bronco Ole Blue - Build IMG_2317
Ford Bronco Ole Blue - Build IMG_2319
AZCoyote
AZCoyote
Wiley
Phoenix
A little more boring black gets replaced by exciting Oxford White.
Ford Bronco Ole Blue - Build IMG_2343
Ford Bronco Ole Blue - Build IMG_2340
Ford Bronco Ole Blue - Build IMG_2341
Ford Bronco Ole Blue - Build IMG_2342
AZCoyote
AZCoyote
Wiley
Phoenix
The new Openroad winch is on. Tomorrow my cutoff switch arrives tomorrow but it’s on and working. Total cost for the 12k winch with two wireless controllers, one wired controller, and 85 feet of synthetic rope? $279 delivered.
Ford Bronco Ole Blue - Build IMG_2662
Ford Bronco Ole Blue - Build IMG_2661
AZCoyote
AZCoyote
Wiley
Phoenix
And just for good safety practices.
Ford Bronco Ole Blue - Build IMG_2671
AZCoyote
AZCoyote
Wiley
Phoenix
Forgot put my Key 200 in here a few weeks ago. It’s setup as front stage and rear pods right now. Amazing change in sound quality with just stock junker speakers.
I’m going to take it apart this weekend and rewire the harness so that the Key run front dash and Kicks separately in bi-amp mode. Rear pods will be off the radio and continue to only provide rear fill.
Lots of sound dampening material is planned.
Ford Bronco Ole Blue - Build IMG_2685
AZCoyote
AZCoyote
Wiley
Phoenix
Replaced an headlight. Secured a ground cable. Installed dash and kick panel speakers and re-tuned the Key 200.4. Don’t have it in me to rewire the front stage today. I’ll be moving to bi-amp in a few weeks. Still another huge jump in sound quality as is. Lots of mid bass. I did pack the cavity with sound deadening to seal all the gaps, gasket tape on all mating surfaces, and foam rings on the front to seal the speaker to the panel. The Memphis as 92db sensitivity and good at low mid frequency so that helps.
Ford Bronco Ole Blue - Build IMG_2745
Ford Bronco Ole Blue - Build IMG_2741
Ford Bronco Ole Blue - Build IMG_2740
Ford Bronco Ole Blue - Build IMG_2739
Ford Bronco Ole Blue - Build IMG_2747
Ford Bronco Ole Blue - Build IMG_2746
Ford Bronco Ole Blue - Build IMG_2743
  • Like
Reactions: I-W
AZCoyote
AZCoyote
Wiley
Phoenix
Lights installed.
Ford Bronco Ole Blue - Build IMG_3331
