Ok, time to pull the trigger: Squatch or no?
NoleDawg
Woodstock, GA
Ford Ranger
I go back and forth on this as well except with a 2dr BL or 2dr BD Sas. When I consider I’m spending damn near 50k on this thing I think looks is a major factor. Just imagine how you’ll feel the first time you walk out to your Bronco in a parking lot and someone with a Sas’d Bronco has parked next to you. Will you be jealous? If the answer is yes - then go for it. You only live once.
My problem is I’m not sure which looks better between the two having seen neither in person.
BennyBronco69
Gordon
BWM M4
Dear friends, it’s time I finalize my build. To Sasquatch or no? I’m in Florida and won’t off-road often. My reason to do it would be looks and resale value. The reason not to do it is I won’t use it, cost, and could delay my order. My build is badlands 4 door.
What would you do?
In FL as well.
Question, if you dont Sasq are you getting the upgraded wheels/tires? Bc if you are, that's only $1,500 more.
If yes, to me its a no-brainer. You like the look more and its only 1500 more.
To me it is worth it bc I dont like the "stock" wheels and at min I would upgrade. I like the look of Sasq most. Gearing. May not net you more in resale but I am guessing you will get more interested people and sell it faster.
TroutHunter
BMW 550
What would you do?
If you have the means, I highly recommend picking one up...
cpmartin1999
chris
Atlanta
2022 Badlands, 2020 VW Atlas
same dilema i really want the MGV, and headlights, in order to make BL similar in $ to wildtrack is do it non sas, so im really starting to think for this money considering it might be the only time i ever "build" a vehicle, i REALLY want to see in person-NON SAS Badlands Vs. SAS wildtrack or OBX, AND i want to see and feel the MGV to see if it is as important as i think it is now?
Dane
Dane
Ram 1500/1966 Ford Mustang
I like the look of the BL stance with the 33's. If I were going BL, I would leave it stock but since I'm going BD, I'm Squatching it. Only reason I'm not going BL is the Orange interior accents. I can't live with that! BD interior is much better.
Drex
Jake
you are going to be paying at the pump and, eventually at the tire store in addition to at the dealer. How much is the 'look' worth to you? Only you can make that call. (nobody else knows your finances, driving habits, what value you place on 'looks', and so on). As to what I would do? (your original question), I will keep the 33's on my 2-door BL as I see no value at all in spending more for a little more clearance when I won't need the clearance I already have. I am more a go than show type of person though.
ausherpharmd
Alex
Illinois
Hyundai Tucson
What would you do?
Pass on it.
Philly
Dallas, TX
2022 JL Rubicon
I feel that if you like how it looks and can afford it without putting yourself in a bad spot, do it. If you like the standard Badlands setup, then don't bother. I wouldn't do it for resale because the additional you may get out of it will probably just cover what you put in to get it anyways.
Keep in mind, larger tires will also mean worse fuel economy. I don't think it will be a huge difference, but it may be a factor for you.
vrtical
Doug AI
GSMNP, TN
Fords
I put in BL non sas with upgraded 33s vs a sas optioned BD which cost just as much. I am putting a 2" leveling kit on it and call it a day, makes a night and day difference just like on the F150s. If I ever want to get crazy I can put larger tires on it and the 4.46 will be just fine, I dont plan on getting on the advanced level rock crawling stuff only medium. For those that want, you can also just put the 4.70 gear in later also, its not that hard. The aftermarket will be much better in a year.
rlynch356
Rob
Apex NC
Defender 90, RRC TDi, 200 series
I included SAS.. I will be taking it off road and will be changing tires so in my mind the 4.7 gears, 8.5" wheels on the 4 door were a no brainer.
Jdon
Oklahoma
Honda Accord sport
Correct me if I’m wrong. But I believe on the bp website you can add the upgraded gearing with the 33”?
Squatch
Always say yes to @Squatch
For MY21, you're stuck with an automatic. It would also be helpful if there was some unobtanium badge or something for the Sasquatch Package which could help the resale value, but right now it's just a warranty-saver if you want 35s.
