OEM Windows Tint % From Factory ?
Desert_6G
Phoenix, AZ
Ranger
For the 4-door owners that do not have tint on their windows. Are your front and rear passengers windows the same factory tint? Is the rear any darker than the front? I had mine tinted a year ago and asked for 20% all around. And my backseat windows are much darker than everything else. It's like a limo tint; it's that dark. I let it slide for so long because I didn't want to deal brining it back in. But now it's just dangerous driving at night with it. It's so dark I can barley see through it.
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
The base is the only trim level that is the same front & rear. All others are as you noted.
coachoates
Chad
Georgia
Bronco Raptor
The back windows are darker from the factory because the factory installs tinted glass.
to make it uniform, you actually don’t tint the back windows but only the front.
Rjacks258
Randy
Punta Gorda, FL
2022 Ford Bronco, 2019 Ford F250, 2009 Ford Ranger
My tint guy measured ours. His meter read the rear passenger doors at 14.4% and the rears at 28%. I matched the fronts and windshield strip to the rear doors.
matteooshe
New York
2022 Bronco
My rear windows were tested at the tint shop and read 15% and then I put my own tint meter on it and it was 15% to double check
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
The rear is darker than the front. Definitely should get it changed.
APhysicist
Atlantic
FJ Cruiser
Even though the rear windows have privacy shading on them, they are not protecting against UV rays. I still tint my rear windows with a lighter film tint, to block UV rays from damaging the rear contents and sun burn passengers.
Scott R Nelson
Meridian, ID
How did you come up with that fact?
Car windows with not tint at all protect from UV rays. It's somewhere on the order of 70% or more.
APhysicist
Atlantic
FJ Cruiser
