OEM top question
sharplawns
Mooresville, Indiana
02 F350 Superduty, 09 Jeep Unlimited, 95 Bronco
Ok I did not get both tops only the hard top. I am looking to buy a OEM soft top from someone that ordered dual tops My question is. Is there any hardware Already mounted to their bronco that is not in the boxes that come inside the bronco?
flip
Phil
IN
www.ruxerparts.com
Fords
Just a word of caution based on some limited information I found in DOW (Ford's parts system). The two brackets behind the rear cargo area trim panels are on backorder but the note in the system, if accurate, says those part numbers are pending obsolesce. I do no see a updated or replacement number in the system as of now so take that for what it's worth. This could also be incorrect information on Ford's end but no way to tell at this point.
Evidence.
Ford Bronco OEM top question 1685651839084
flip
Phil
IN
www.ruxerparts.com
Fords
You will need...Please feel free to correct if this isn't complete
2- M2DZ-7829452-A Top frame brackets
10- W707288-S442 Top frame bracket and frame bolts
1- M2DZ-78515A52-B Roll bar top bracket
1- M2DZ-78515A53-B Roll bar top bracket
4- W721070-S450B Top bracket bolts
1- M2DZ-78255A34-BA Side window C pillar trim
1- M2DZ-78255A35-BA Side window C pillar trim
2- M2DZ-78515A54-B Rear hatch latch brackets
2- W718804-S450B Rear hatch latch bracket bolts
MolonLabe
Mel
Basesquatch
What are these for?
Dantastic
Daniel
Lake Saint Louis, MO
www.youtube.com
OBX Sas Bronco, Mazda CX-5
Sorry to resurrect a dead thread (I know taboo), just want your part list to get the recs it deserves. Just placed an order with Ruxer (I know that the roll bar brackets are out of stock), and I didn't need as many bolts/the side window panel trims (as I have those). Do you know if the soft top plastic bracket covers are orderable? I think the hardtop ones are different ....
Oh and ordered the latch brackets from Mountains2Metal since there seems to be some weird pricing going on
flip
Phil
IN
www.ruxerparts.com
Fords
We have an inquiry in with Ford for the brackets since we ordered more about a year ago and they just finally came in with the new number and pricing. If price is correct, we're sending them back.
:oops::oops::oops:
Ford Bronco OEM top question 1712761357519-ca
I can see why M2M makes their version now - it's a steal
Dantastic
Daniel
www.youtube.com
I don't blame you all at all. That is ridiculous. Do you know if this part is orderable? If not, I'll either have to go without a plastic cover when using the soft top or cut my piece:
Ford Bronco OEM top question 1712761711234-p9
:oops::oops::oops:
Yeah ... I just about cried when I saw that. So thankful for @Mountains2Metal
Dantastic
Daniel
www.youtube.com
flip
Phil
IN
www.ruxerparts.com
Fords
Is that the $1,300.00 Ford one?
Yup. Just looked at the COPIS case my PM opened and they changed list to $670.47 so I sent them the same pic and said the decimal needs to move one more place to the left. I can see a list of $67.00 but what they "confirmed" to be the new correct amount is still not possible.
