OE Sasquatch replacement tires
Last Ride Bronco
southern USA
Nissan pup
I'm probably going to replace my OE tires with something different when they wear out, but if I had a tire destroyed with only a few thousand miles, I would want to get a matching tire. As most of you know the Territory MT is basically a wrangler tire without Wrangler on it. Instead it has Goodyear on it, twice. Out of curiosity, I checked around to see if you could get the OE tire. Turns out, you can't. Most tire dealers don't even know the Bronco tire is different and that it doesn't have Wrangler on it. I called Goodyear and they seem to think that only the MAP has them. Anyone know any different?
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Yeah my dealer could order them no problem.
I'm currently getting 18.5mpg in my 2.3L 10spd BaseSquatch but I am only 250 miles deep and taking it easy on the engine.
The Goodyears are pretty quiet, and lightweight for what they are. I had originally planned to swap them at purchase for Wildpeak ATs but my stay in ice mountain kiboshed those plans.
The Wildpeaks (or really any AT tire) are going to be significantly heavier and I assume will have a decent impact on my MPGs.
Last Ride Bronco
Last Ride Bronco
southern USA
Nissan pup
Last Ride Bronco
Last Ride Bronco
southern USA
Nissan pup
I asked my dealership and their response was:
Ford Bronco OE Sasquatch replacement tires 57DEA80D-8A41-456E-A308-77AB4DCD2817
I possibly could replace OE with OE, if I get good tread wear . They are definitely light which helps with mpg.
Raptor911
Raptor911
Broadlands, VA
I would call them and ask to make sure.
I know tirerack sells the specific KO2 for in the 35s and 37s for the F150 Raptor. 37 is below .. notice in the description it says FP Ford Performance
Ford Bronco OE Sasquatch replacement tires 1651084739147
Thanks for the response. That is definitely a picture of them. The heading/description has Wrangler in it. Makes me wonder which version you would get if I ordered one?
cscottp67
Richmond TX
19 F-250 / 20 f-150
“My tire Dealer said!” Sorry couldn’t resist discount tire said they can order one and that Sams or Walmart carry them.
gryphon1231
dj
Miami FL
na
It is a Good Year Wrangler Territory MT. If I had to guess/bet, It probably says good year on one side and wrangler on the other.
