Non Bose system with factory sub?
Gentryg
Gentry
Prosper, TX
23 Badlands high package.. Setting up to upgrade system and I noticed there’s a subwoofer?? What am I missing here? How does non Bose system have a subwoofer?
Ford Bronco Non Bose system with factory sub? D7713774-1C58-4626-91C0-C18AA6B9F32F
tater_70
Terry
64 Fairlane, 1973 Bronco, 75 F-100
I believe the 23's were to come with a 7 speaker system which included a subwoofer. Due to constraints the sub was deleted, still a 6 speaker system. if you were to look inside you'll find a speaker missing the magnet and an empty circuit board. Although you may be one of the lucky early orders that received the 7 speaker system before the delete. Does order show a -$250 delete?
Gentryg
Gentryg
Gentry
Prosper, TX
There’s definitely a very crappy subwoofer producing some bass from the enclosure. I haven’t taken the panel off to investigate yet. But there’s definitely a sub. What’s confusing is that I don’t have a front Dash center speaker
BigHoof
PA
Ram 2500
When was yours built? After about mid December, the sub and amp was deleted an reflected on your window sticker. Still has the panel and a non functioning carcass of a speaker installed.
BigCatKale
Everglades
Randy
Broken Arrow, OK
2022 Bronco Everglades / 2021 Kia Telluride
Everglades
And you won’t. It is still the standard audio setup. You are just one of the few in 23MY to get the added-on sub before they deleted it again due to constraints.
Gentryg
Gentryg
Gentry
Prosper, TX
Got it. Thanks! Now I need to return the Hideaway sub and use the factory enclosure
gaaangs
Ohio
Jeep
This is my plan. What's size sub will it fit and is it enough? And then what about the amp - is there one for the sub? That's the questions.
Gentryg
Gentryg
Gentry
Prosper, TX
Ill let you know when I find time to remove the rear panel
MotoFish
CO
Fords
Following.
We have a build date of 12/5 on our OBX. Curious to see what is equipped if it ever arrives at the dealership. Is this the same sub that's making the noises driving people nuts?
BIOHAZARDCYCLES
Thomas
Groveland
2017 raptor 2021 xt6
i have a 23 badlands high as well.. mine had a jan 30th build date and came with working sub & amp behind there.. if anyone wants it sub/amp i took it out..
Karl_in_Chicago
Karl
Chicago
That's quite an outlier/rare bird with that build date AND working sub. Wonder how/why that worked like that.
JeffL
Massachusetts
2019 Challenger Hellcat Redeye / 2023 Base SAS
my 23 base sas has the working sub, i feel special. going to rip it all out though
BIOHAZARDCYCLES
Thomas
Groveland
ill take a look when i get home , its probably non working.. i just read the other thread that shows them with the amp & speaker but its fake.. i didnt even have the car 24 hours before i ripped it out so never actually heard it work..
