No reverse lights but camera is on
Coronabronco
Julio
Miami
Bronco Badlands
Has anyone had any issues with their reverse lights not coming on when going in reverse? I resolve it by shutting off the car and starting it back up. Issue just started. Yes I have aftermarket lights. I’ve had them on for months but this issue just started. When this issue happens the camera does work. Bronco enrages reverse (manual transmission) it shows it on screen to
Chopper_Man
2024 Bronco 2dr
Put your OEM lights back in and see if the problem persists.
Coronabronco
Coronabronco
Julio
Miami
Bronco Badlands
Put your OEM lights back in and see the the problem persists.
The only aftermarket lights are the diode chase combo. I’ve unplugged those and the issue still happens intermittently
Ducati1098
Are the aftermarket lights spliced into your factory reverse light circuits?
Coronabronco
Coronabronco
Julio
Miami
Bronco Badlands
Not exactly. It’s a wire harness but it never gave issues before
Ford Bronco No reverse lights but camera is on IMG_4995
Sounds like it may be now.
May be worth checking to see if a DTC is set for missing or shorted lamp. It wouldn’t necessarily set the CEL
