- Jacob
- Aug 26, 2021
- 21
- 129
- 249
- Ogden, UT
- Website
- www.holley.com
- 2022 Bronco
- Undecided
Our new Flashcal 1546 is the easiest, and by far the most budget-friendly, way to unlock numerous features not available on your new Bronco from the factory, and still offers the classic adjustments like speedometer correction. This handheld tuner supports both the 2.3L 4cyl and 2.7l 6cyl engines in either manual or automatic transmission. Flashcal 1546 calibrates your Bronco’s auxiliary systems such as speedometer and lighting, and does not alter factory powertrain specifications.
Superchips Flashcal 1546 for 2021+ Ford Bronco
Features include:
Features include:
- Auto Start/Stop Disable: Remains off with every restart, and can be reenabled with the Flashcal any time
- Silent Mode: Turns off most cabin and exterior lights, and door chime with open door, ignition chime remains
- Honk Warning Disable: 2-honk warning when driver exits running vehicle with key fob
- Remote Start: Selects engine run time duration for 0, 5, 10, 15 mins
- Speedometer adjust for Tire Size 28.25 - 36.75"
- Fog Lights: enable "Bambi Mode" for simultaneous use of fog lights with high-beams
- Headlamps Position Setting: option for headlamps to return to "Auto Lamps" or remain at last known position
- Auto Lights Delay: duration headlights illuminate after driver exit, 0, 5, 10, 20, 60, or 120 s.
- Daytime Running Light disable or enable
- TPMS Disable, for off-road wheels and tires
- Independent TPMS threshold: Front and rear axles can be set differently from 1- 90 psi.
- Lock Feedback Lights: Enables hazard blink with unlock command
- Auto Unlock: Vehicle unlocks with ignition off
- Auto Lock: Disables factory setting to lock doors when vehicle is in motion
- Auto Relock: Disables factory setting to re-lock doors 45 seconds after unlocking
- Remote Unlock: Option to trigger all doors or just driver door
