NEW PLUGNPLAYKITS HARNESS TO ADD A SUB AMP TO THE B & O SYSTEM
plugnplaykits
Joe
Ct
We are proud to announce our new harness which will allow you to add a sub amplifier to your factory B & O system while leaving everything else intact . This Harness while while you to plug in an audio control LLC to I which will allow you to have sub RCA outputs and remote wire to connect your sub amplifier . Also this harness will connect directly to the audio control amplifiers which has a built-in LC2i in it and no extra parts will be needed . This kit will also work with our kicker amplifiers .
https://plugnplaykits.com/collectio...020-ford-f150-with-b-o-plug-play-harness-kits
