I wanted to explain the two different ways on how to upgrade the B&O system. This is from my new listing, which is the second picture of the red bronco right on the homepage of my site. I hope this helps people understand how the B&O system works, and how to properly upgrade it.
ADDING A SUB AND SUB AMP ONLY OR ADDING A FULL SYSTEM . WITH THE B & O SYSTEM ADDING A SUB ONLY THE B &O AMP STAYS FUNCTIONAL IN THE VEHICLE AND A T HARNESS WITH A LC2I OR COMPATIBLE AMP THAT ACCEPTS THE B & O INPUT TO PROVIDE SIGNAL TO THE SUB .
WHEN UPGRADING THE FULL SYSTEM A INTERFACE IS NOW NEEDED AS THE B & O AMP IS COMPLETELY REMOVE FROM THE VEHICLE . THE INTERFACE PLUGS INTO WHERE THE FACTORY B & 0 AMP WAS AND WILL PROVIDE YOU WITH YOUR FRONT REAR AND SUB OUTPUTS TO CONNECT TO YOUR AFTERMARKET AMPS WHILE RETAINING ALL THE VEHICLE FACTORY RADIO FUNCTIONS WORKING AS NORMAL.
THE B & O AMP DOES NOT RUN ALL 6 SPEAKERS IN A BRONCO . THE REAR SPEAKERS AND CENTER CHANNEL RUN OFF OF THE FACTORY RADIO POWER . WHEN THE B & O AMP IS REMOVED THESE SPEAKERS WILL NO LONGER WORK OFF OF THE RADIO AND A 6 CHANNEL AMP IS REQUIRED TO RE POWER ALL 6 SPEAKERS . WHEN BYPASSING A FACTORY AMP THE CENTER CHANNEL SPEAKER IS NEVER AMPLIFIED AND NO LONGER USED .
THE INTERFACE WILL COME WITH 2 INCLUDED HARNESS . 1 IS FOR THE AUDIO CONTROL MODULE (ACM ) BEHIND YOUR HEATING CONTROLS TO GIVE YOU THE REAR SPEAKER POD WIRES TO RECONNECT THE REAR SPEAKERS TO THE AMP . AND THE OTHER HARNESS PLUGS IN AT THE B & O PLUG THAT GIVES YOU ALL OF THE OTHER SPEAKER WIRES
