NEW M6PRO HIGH POWER 6 CH DSP AMP
plugnplaykits
Joe
Ct
This is just an update for those of you that are waiting for the musway m6pro . Amps just came in will have them in stock by next week only getting a few amps So if you want one, call me tomorrow to pre-order to lock up one . this is a great amp for the regular and b & 0 upgrade .
6-Channel Full Range Class D Amplifier with 10-Channel Digital Sound Processor
  • Start-Stop ready
  • EPS (Intelligent High-Level Input-Error Protection System)
  • Brushed aluminum heat sink and end panels
  • Auto Turn On via DC Offset or Signal Sensing
  • Utilizes 4-fold laminated circuit boards that allows for small size and effectively suppresses EMI (RF) interference which is a must with full range Class D amplifiers. Passes the difficult European EMI standards
  • Output Clipping LED
  • With the easy-to-use MUSWAY PC software, the M6 can be configured perfectly and in real time via PC or the new Musway app for your smartphone or tablet.
  • With the 3 optional USB Bluetooth dongles you can stream audio, stream aptX HD Hi Res audio, and can have app control for DSP Tuning from your smartphone or tablet. Also available is the optional DRC1 digital remote control with OLED display that puts the control of your audio system at your fingertips.
SpecificationsOptional Accessories
Product Specifications:
  • OUTPUT POWER (RMS) @ 13.8 VDC, 1% THD
    • 6 x 235 Watts RMS at 2 Ohms (DHR*)
    • 6 x 120 Watts RMS at 4 Ohms
    • 6 x 200 Watts RMS at 2 Ohms
    • Bridged: 3 x 400 Watts RMS at 4 Ohms
  • High Level Input 7 - 29V RMS
  • Low Level Input* (AUX) 1 - 8V RMS
Squatch
Is this a 6-channel setup meant to handle the speakers individually:
2x 4" dash speakers
2x 6.5" kick panel speakers
2x 6.5" (pods) rear speakers
Then, a separate amplifier to add a subwoofer?
plugnplaykits
plugnplaykits
Joe
Ct
That would be the right way to do it as the M6 pro has an additional extra two channels of dsp output and can control 2 other amps through the DSP as well . The regular m6 and all of. Musway dsp amps have an additional 2 channels of output to control other amplifiers. The point of using a six channel amp in the bronco is to separate the 4 inch speakers from the 6 1/2 putting each speaker on their own channel so they can adjust power level and to be tuned individually as they should be .
