NEW MUSWAY 3 CH AMP
plugnplaykits
Joe
Ct
We are proud to be adding the new musway NX 700.3 this is a compact three channel amplifier perfect on the base model or B & O bronco to run rear pods plus a new subwoofer or front components with a subwoofer. This amp is the same size as a kicker key and can’t fit on the steering wheel bracket or on top of the sub enclosure in the rear. Should be added to the site in the next few days.. will post link here
Product Specifications
Model: NX700.3
Channels: 3
Circuit: Digital Class D
Power @ 14.4 V (≤1% THD+N):
CH1 / CH2:
Watts @ 4 Ohms: 2 × 85
Watts @ 2 Ohms: 2 × 150
Watts @ 4 Ohms bridged: 1 × 300
SUB:
Watts @ 4 Ohms: 1 × 250
Watts @ 2 Ohms: 1 × 425
Frequency Range: 4 – 50,000 Hz @ -3 dB
Signal-to-noise Ratio: > 99 dB
THD+N @ 5 W: < 0.02 %
Input Sensitivity: 470 mV – 8.7 V
Filter Section (CH1 / CH2):
Low Pass Filter or High Pass Filter: 20 – 400 Hz
Filter Section (SUB):
Low Pass Filter: 50 – 250 Hz
Subsonic Filter: 10 – 50 Hz
Bass Boost @ 40 Hz: 0 – 18 dB
Operating Voltage: 10.5 – 16.5 V (max. 5 sec. down to 7 V)
Start-stop Capability: Yes
High Level Input with EPS*: Yes (Type D, via included cable connectors)
Auto Turn-on: Yes (via High Level Input)
Bass Level Remote Controller (SUB): Yes
Fuse (external): 60 A
Dimensions:
Width: 89 mm
Height: 41 mm
Length: 168 mm
Product Description
Ford Bronco NEW MUSWAY 3 CH AMP IMG_8334
