New interface for B&O audio to do full system integration - from PlugNPlayKits.com
plugnplaykits
Ct
We will now be offering a new DSP interface that allows you to do a full system in vehicles with the B & O sound system . These kits will be available next week . The price will be $500 at www.Plugnplaykits.com under the bronco listing . I will add a link once this is added to the site
AXDSPX-A2B2
Axxess B&O A2B/DSP Pkg w/Amp Bypass Harness Ford 2015-Up
USA MSRP: $559.00 USD
Product
Features
Tech Docs
& Instructions
Vehicle
Applications
Upgrade your sound system with this cost-effective, easy-to-install DSP package that includes a vehicle-specific T-harness.
Complete Tuning Control
Installers will have full control to fine-tune each of the 10 channel outputs individually, controlled wirelessly via a free app available for smartphones and tablets. The app makes tuning easy with a 31-band graphic EQ and up to 10ms time delay for each channel, with independent high pass, low pass, and bandpass filters.
Retain Features with a Built-in Interface
Utilizing Axxess’s data interface technology, the AXDSP-X goes beyond what a traditional DSP can do and retains many of the features commonly lost when upgrading a sound system. Voice prompts, parking sensor chimes, and other factory chimes are retained with an adjustable volume control that many traditional DSPs cannot offer. This is a cost-effective solution for customers who want to retain their factory radio and improve their vehicle sound quality, while still retaining systems like SYNC® or OnStar®.
One Solution, Many Applications
The AXDSP-X solution already works with a wide range of vehicle applications and systems, including OE or aftermarket radios, and fixed-level analog and/or digitally controlled amplified systems, in addition to non-amplified vehicles that do not have chimes. The AXDSP-X works with all the existing DSP T-harnesses and still offers the same easy installation behind the radio.
Package includes the A2B interface, vehicle-specific T-harness, and amplifier bypass harness
Designed for select vehicles with a B&O A2B amplifier
Uses AXDSP-X technology
31-band graphic EQ or 5-band Parametric EQ
Selectable high pass, low pass, or bandpass filters on each channel
6 inputs and 10 individually assignable outputs
Independent equalization on each of the 6 outputs
Selectable slope (12, 24, 36, or 48db per octave)
Each channel can be delayed independently for up to 10ms
Easy behind the radio installation in most applications
Can be used with OE and aftermarket radios
Clipping detection and limiting circuits
Internal header port for adding interface modules
Bass knob included
Retains OE voice prompts (SYNC®) with adjustable level
Retains factory chimes, including parking sensor and cross path detection alerts with adjustable chime level
Chimes and voice prompts go through the aftermarket amplifier
Factory amplifier does NOT need to be retained
Settings adjusted wirelessly in a smart device application (tablet or mobile phone)
Read, write, and store configurations for future recall
Password-protect feature is available in the mobile app
Micro “B” USB updatable
1-year limited warranty
mcinfantry
Lee
Louisiana
Badlands 2 door
Nice!
plugnplaykits
plugnplaykits
Ct
I will be able to also get the price lower $475 if people are willing to do a pre-order and I can put a quantity order in
Bronco cat
Carl
Morgantown wv
‘20 Explorer ST, ‘19 GT350, ‘21 Bronco Sport
Where do I need to sign up :)
Snowdogyyz
23 Ford Bronco Wildtrak
I’m interested too. Just to clarify- I’d need to buy this AND an amp correct? I already have an amp for my sub connected but nothing up front. Thanks!
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
So in layman’s terms, what does this do?
WildArea51
Richard
Louisville, KY
2022 Bronco Wildtrak
Sign me up. I already have a Key 200.4 waiting, just needed this kit for it all to come together.
plugnplaykits
plugnplaykits
Ct
Call me on Tuesday or Wednesday should have a few in by then going to be a while for this group by thing as your needs to be enough people to make it work
Erock
US
2018 F150 Alpine edition
I have an LC7i and was planning to just get the cable for that… would this bypass the need for it or just enhance it? Also, would I need an additional cable from the dsp to the LC7i?
plugnplaykits
plugnplaykits
Ct
I just received four of these units contact me directly if interested
plugnplaykits
plugnplaykits
Ct
I have just added this kit to the website it is right on the top of the homepage
