Fastmc25
Fastmc25
East Tennessee
24 Big Bend
Did everyone get this same paper. Nothing on it says ford. Dont want to plug in something thats only ment for mopar
I didn’t get any paper in my box. It was just a box with the obd doggle and that power tech chip. I asked the tech representative and he said that that was just for jeeps.
You’d think they’d save money by taking those out of the boxes when they sell to a Bronco person.
Tybh88
Tyler
If you pull yhe foam out then theres another lid with this paper and stickers
psdtime
Tom
CA
2026 Bronco
If it's not obvious, can someone take a photo of the parts we use for the broncos?
N8do
Nate
IN
24 Badlands Sasq hardtop 2.7 /86 4X4 trim, 351W, 35s, 4.86 + lockers /02 Taco 4d
//NOTE//
It seems that if I go into the Speedo Adj tab, and manually load the tire diam.....if it isn't a number it likes....it gave me the U0403 and the WRENCH, messing up the 4x4 monitor sys.
The Tire Size Wiz seems to clear it up....but the Wiz and Google did not agree on GPS speed; at least 2+ mph disparity at 60.
Going to play with it more and try to dial it in, or just let the Wizard be the wizard.
Very happy with Sport Mode, Tire Low Alert Adj, and Seat Belt Warn Dis!!
And yes, the double tap on the PANIC was a must.....so tired of pocket jump scares. Lol
I am interested in the 87 Tune as soon as its Avail!
Ford Bronco NEW Flashcal+ Bronco Support! 1665078156265
N8do
Nate
IN
Use the larger OBDI port, and bluetooth to phone. the other item is if you have other accessories installed in line with the OBDI????
Fastmc25
Fastmc25
East Tennessee
24 Big Bend
Ha! You’re good 😂😎
Glad i didn’t need, because it would be useless for Broncos
But i like Stickers! 😂
Ford Bronco NEW Flashcal+ Bronco Support! IMG_3801
thanks 👍
N8do
Nate
IN
Side note here.........
Has anyone else been locked out of their FORD App "Add Service Record" since the Flashcal+ install????
It is not allowing me to update anything, such as tires installed. Weird 🤔 😬
I've tried two devices and it comes back:
Please try again Later
The app is not responding
Inquiring minds want to know!!!!:oops:
CalamariKId
Charles
pinPed-nutko2-vikjib
Sprinter 4x4; GV70, CR-V and former Jeep Owner
Brake hold is on the list already ;)
Not sure about cruise control-control, but we can check it out.
I don't see brake hold on the menu. I referring to the ability for the vehicle to keep the brakes on when at a stop without having to continue to press the brake pedal.
psdtime
Tom
CA
2026 Bronco
It's that a factory setting? Mine does that on inclines.
Fastmc25
Fastmc25
East Tennessee
24 Big Bend
Mine seems to work as designed.
24GTBadlands
IL
24 Badlands v6 (3 inch lift), 24 S650 with PP GT (pre-production), 1971 Mach1
I had this issue weeks ago when I tried to add an oil change to my 24 S650.
So I don’t believe Ford has a Spite Bot in the app for when you change something like removing Double Honk.
chopperbobby
bob
northern ky
2025 bronco
2025 obx anyne have ant problems with adding baja goat. Want to add but would like to know there were no problems. I did do the panic button to to. Love it
Nick72
Nick
North GA
2021 Bronco Base(Traded), 2025 Bronco Outer Banks
I added Baja with no issues. 2025 obx also.
