Need some help 2.3 L Ford Performance upgrade
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
I had my dealer install the Ford performance upgrade for my 2.3 L Bronco several months ago. I recently went to check for an update on the Ford site and discovered I do not have the plug for the screen to attach to my computer. Dealer claims they don’t have it and this item appears not to be sold separately by Ford. I’m reaching out to see if anyone suggests a potential work around idea.
Thanks in advance.
Spooled
Republic of Texas
Raptor, Model 3
The module came with the cable needed since the first thing you have to do is connect it to a PC. You're saying the dealer didn't give you the cable back when they installed the tune?
The little screen/dongle, a usb cable, a mounting bracket and the ODB cable are all part of the package. You need to scream at your dealer that installed it. The screen/dongle is locked to your Bronco so it’s not like they can just use the same one over and over.
That said - if the ~only~ thing you are missing is the cable for the computer / it is just a standard micro USB and isn’t proprietary. There should be 2 ports on the module - the RJ45 for the ODB cable on back, and a micro USB on top for the computer
beerbar
Bubba
2023 Bronco
if you still have the box, see of they printed the cable type and dongle included on the box and order one from Amazon.
rpaluch1
rpaluch1
Rudy
Tecumseh Mi
Ford Bronco
Thanks. Much appreciated.
