Need help with KC Slimlite install
MikeStLouis
St. Louis, MO
2022 Bronco
Gang: Just got my Bronco a couple weeks ago and am excited to get some lights on. I bought the Slimlites and it comes with a wiring harness. The harness has a switch built in and I’m not sure how to install this with the Bronco Aux/light switches. Anyone have an easy answer. Thanks so much
Ford Bronco Need help with KC Slimlite install B40B3992-AAC8-4484-AE74-BB1B93F541CB
Ford Bronco Need help with KC Slimlite install 9FAFD2E7-7982-4504-BBEC-E43ABD404C5B
Madman
Kevin
2017 Ford Raptor, 1948 Willys CJ2A, 2021 Bronco
Do you have aux switches on your bronco? If so you don't need their wiring harness....find the current rating of the lights and use the correct current rating of the aux switches (my guess would be 4-6) and use the resources here to find the associated power from the aux switch to run to power the lights (you'll have to route a wire from the passengers side though to the feed) and run the Ground from the lights to any grounding point.
MikeStLouis
MikeStLouis
St. Louis, MO
2022 Bronco
MAD: Yes, I do have the aux switch bank. KC comes with the harness that plugs neatly into the fixture. But then it is an octopus of wires that includes a fuse and a switch that I obviously don’t need. So I am hoping someone can tell me if I can just CUT the harness (where I have no idea) and wire it directly into AUX2. Thanks for replying! I appreciate it a lot
blackh8552
New Jersey
Obx Sasquatch 2.7 and explorer ST
tie the red and yellow together. You are sending +12v from supply to the load. Basically you are removing the switch
mootruck98
Kyle
Madison, MS
2006 Nissan Titan
What bracket did you use to mount the lights? I can't find anything specific to KC and Bronco, and the ones I've seen for Bronco can't tell if the large bolt on the slimlites will fit.
MikeStLouis
MikeStLouis
St. Louis, MO
2022 Bronco
Are you talking about the Pillar Lights - or the windshield lights. I used the same brackets everyone has been chatting about on here.
Bay Area Metal for the windshield.
I can look up the pillar mount - if you need it.
mootruck98
Kyle
Madison, MS
2006 Nissan Titan
The pillar light mount is what I am looking for.
IXxMcCoyxXl
Fredericton, NB
2021 Ford Bronco 2Dr
just cut the harness ahead of the switch and ground negative wire then connect positive to the switch wire you want on top of harness. I’ve done it with with my slimlites and ditch light harness from kc. no issues.
Badassbronco
Georgia
It looks like there are three wires. Which one is positive, negative, and the other is what? Hey
IXxMcCoyxXl
Fredericton, NB
It is a mulit function wire, not used if using oem switches for on off
Badassbronco
Georgia
Did you get it to work? Also I was wondering if you kept the inline fuse on the positive wire.
‘21OBX
90Bronco19
2022 bronco outer banks
Strip back the harness at the closest point to your upfitter wires. Toss the yellow out( upfitters are already fused). Hook the red to the upfitter switch ground the earth to a convenient location or the battery. And you done enjoy your lights.
orion
Jeremy
17' F-250, 17' Explorer
Eddited to add: Sorry '21OBX, I think I started my long winded post the same time you did, lol...
I know this is late but for future members this is all one would need to do in this application. You would just connect red wire to auxiliary switch and black wire to ground. The yellow wire in the supplied harness only goes from battery to supplied switch.
If you were going to use the supplied harness, the power would travel like this:
Battery + > Yellow Wire > Fuse > Yellow Wire > Switch Supply > Switch Load > Red Wire > Light 1 and Light 2 > Ground
So when using the Aux Switches, they are already fused and have our switched load under the hood. You then eliminate all before the red wire, connect red wire to Aux Switch wire of your choice and connect the ground to battery negative or a chassis ground connection.
Hopefully that helps in the future for other members.
