need help turning flashers on.....
phillyfx4
Rich
Phila., PA
2008 F 150 4X4
I'm a computer IDIOT.....if I need them where is the switch to turn on my flashers ?
1000 miles on my 25 Outer Banks SAS
thanks
yes, i'm embarrassed :rolleyes:
phillyfx4
Rich
Phila., PA
2008 F 150 4X4
my last ride was a 2008 F 150 FX4, ..... this whole experience is challenging .....
now, on to .....
Symbols Used On Your Instrument Cluster
is making me inhale about 5 white claw hard ciders before I even attempt them 🧐
KABQ
Aaron
Albuquerque, NM
now, on to .....
Ford Bronco need help turning flashers on..... zuemz0x1p9arzjp4fq2
TheKim
Kim
Hey, welcome to Bronco ownership.
The forum can be extremely helpful, but you will get picked on. It won't be just you, it's everyone, and it's USUALLY in good fun 😆
I hope you enjoy your new ride, and have some awesome adventures. 🤘
CalvinT
Calvin
Phoenix, AZ
If you're colorblind like I am, you can't see the emblem on the flasher switch except under bright light. When I picked up my Bronco I asked the salesman what the blank switch was on the extreme right of the HERO switches. He told me it was the 4 way flashers. Later with better lighting I could see the emblem. The red turns to grey unless lighting is bright enough.
If Ford had used the same color as they did for the other HERO switches there would be no problem. But there's probably a DOT regulation dictating the color for the flasher switch emblem.
It's a common screw up. Companies don't take colorblindness into consideration when they choose colors. Sometimes it affects safety like with the flasher switch.
Another example is black or blue printing on a red background. Red is selected because it signifies danger, but then they blow it by using black or blue printing. Again very difficult to read unless you have perfect color vision. They should use white on red. I could go on, but I won't.
Eight percent of men are colorblind. But I'm willing to bet perfect color vision is one of the qualifications to be a designer.
