NEED HELP ASAP FOR CONSOLE VAULT
Kevink820
Kevin
St. Louis, MO
2022 4door base
Just got a new console vault and when I was resetting the code my hand slipped and set it on a code I can not figure out. How should I go about resetting it and setting the code I wanted to set it as in the first place.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Just keep guessing
JMB
All Fords
This is not a problem as long as you have the vault door open when you are setting and testing the new combination. What you don't want to do is shut the vault door and reset the lock before you verify that the combo is set as expected.
Lifeliberty
Moonbeam👀
Columbus, OH
If it were readily known it wouldn't be much of a vault.
I think this pretty much nailed it. If you could get in without knowing the code, it wouldn't be worth having.
Jawaburger
Champaign, IL
2022 Bronco, 2 Door, Manual, Cactus Gray
I assume your local Ford dealer can help you reset the code. My keyless entry came with a code that works even if you add your own code, have you tried the original code? Never had the vault, so don't know much about it.
j_marinelli
Spring Branch, TX.
Maybe try reaching out to Console Vault to see if they can help. I'm sure you are not the first to do this.
Arokcrwlr
Kraig
US - Alabama
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
Assuming it's installed and locked it may take awhile. There are only 10,000 possible combinations (or 1000 if you bought the 3 digit version). You might have to try nearly all of them before you hit on the right one. Either that or an angle grinder with a cutoff wheel and buy another one. I wouldn't recommend trying to pry it open. The plastic console is likely to break before the steel vault door gives way.
I bought the version with keys, so I could be wrong.
