My new ARB summit bumper installed
breaddrink
Washington
Nissan's
Loosen the upper intercooler bolts. It will allow you to raise the intercooler enough to get the lower bolts back in. It is tough and slow going. I used a flex head long ratcheting wrench once I had them started.
https://www.gearwrench.com/all-tool...c-gearboxtm-double-flex-ratcheting-wrench-set
That is the same set I have... Can't imagine how else it could be reached.
Good idea on loosening the intercooler above.
If you have a moment, would you be able to specify which bolts you mean? A picture or a diagram... Might help future generations of installers.
I'll take a look myself after work.
You're the first I've come across to suggest this. Could be a game changer.
Were you working with the 2.7?
Silver-Bolt
Eureka, MT
I am currently 600 miles away from our Bronco so I can't help with photos. Ours is a 2.7L. All that I remember is that those two bolts took the majority of the install time. Once I had the bolts lined up I used my finger tips to very slowly get the started in the threads. Once they threads down far enough to get a wrench on it was easy from that point on. Going from memory, the upper I/C bolts are near the base of the radiator.
breaddrink
Washington
Nissan's
Right. I have the upper IC bolts out. It's returning them inside the bracket, with a packer washer underneath in that space I'm having trouble with...
Now in questioning if we're talking about the same books. It sounds as though you had a way to free up space a little more? Or perhaps I'm mistaken?
Silver-Bolt
Eureka, MT
We are talking about the same bolts. I did have another person write asking the same questions. He ended up cutting the two lower bolts slightly shorter in order to get them back in. I wonder if Ford changed the bolt length at some point?
35tires
'23 Bronco, '21 4Runner
Good looking Bronco! Curious if you notice anything from the extra weight up front?
I don't have the ARB but my front has a fairly heavy steel bumper and full steel skids. The front now sags a LOT more than it did after about a year of use. I can't make up a number, but it's bad enough it's time for new shocks/springs/something. It's very noticeable over time. Wear and tear I guess.
breaddrink
Washington
Nissan's
My SAS Badlands dropped 3/4" in the front with exact same bumper/winch setup. Though I installed Diode Dynamics fogs.
Same here. I even stopped short of installing the winch...
I feel the badlands suspension is so stiff that it might actually help counter it a little, but it def lost some height with the bumper.
Did you do anything for the rear bumper? Somehow ones that encorperate a license plate are rare.
