Now they just gotta design a quick release on that back windshield!Rear window removal is super easy! However, the steps in the little "quick start" booklet don't explain it properly at all. So, here is how it goes ... You use the tools provided in the Bronco kit (comes in your glove box), which makes it easy. Remove the bolt that is on the inside rear end of the quarter window. Put that in your tool bag. Once you do this, the glass will pop out a tiny amount. It's not going to fall out, but it was easy enough to hold one hand on the outside side of the window (just in case) while removing the bolt. (I'm 5'6" for reaching reference.) Then you move outside and slide the glass portion out, horizontally, toward the back of the vehicle. There are 2 ball / socket joints that the glass pops into so it's a little wiggle to get them free, but very light pressure is all it takes. The glass isn't heavy, and was very easy to handle.
