Multi tire inflation for your Trickflate
Status
Not open for further replies.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Our long awaited multi tire hoses are in stock. Sold as a 2 tire hose for just $49.99, add a second hose to do all 4 tires.
Buy here!
Ford Bronco Multi tire inflation for your Trickflate PXL_20230514_015729676
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Buy here!
Tricky's got hose, hooooose, shipped to your area codes!
TheKim
Kim
Buy here!
So, to do this right, I need 2 sets of hoses, the pressure switch, and a Trickflate?
Should I throw in some chucks?
Do I need the 2 way manifold to do all 4 tires at once?
Side note - awesome meeting you in Moab at the Safari!
Hope you had a great trip!
Tricky Dick
Dick
PNW
It was awesome, I wish we'd been on more trails together.
The hoses come with chucks so you just need a 2 way with gauge, two 2 way hoses, and a pressure switch kit. All that should run about half the price of what the other guys charge.
Bikeric
Tulsa
2022 Badlands LUX on 37's
Looking at the quick connects, they appear to be the style that I can't easily use with my beadlocks and short valve stems. Are they able to be unthreaded and replaced with a different locking style?
My valve stems look like they just came out of a cold creek crossing, is all.
TheKim
Kim
Looks like the cheaper hoses are sold out - guessing the XLs are needed for school buses anyway?
(4 door Cyber Orange)
Does this look good?
Ford Bronco Multi tire inflation for your Trickflate 1684958055182
Tricky Dick
Dick
PNW
I actually do have some of the normal ones I just haven't updated the inventory. Give me an hour...
Tricky Dick
Dick
PNW
They do thread off. They work with Sas wheels but it's a little tight getting in there.
Tricky Dick
Dick
PNW
TheKim
Kim
Thanks for adding that...
Went with the longer hose anyway, figure it'll work better for the moar door. 😆
Order placed. About time I got a proper compressor instead of my little Amazon no name brand one.
cobro92
Denver
F350 7.3 Powerstroke
Installed the pressure switch kit on the trickflate and ordered the 4 tire inflation system as well. Works fantastically. I’m a real wiring noob and it was done in 45 minutes from beginning to end. Make sure to use Teflon tape on every piece because they will leak if you don’t.
Ford Bronco Multi tire inflation for your Trickflate 8F4DC99C-FE56-41FA-809B-F6B52335F404
Status
