Sold: Trickflate Giveaway!
Status
Not open for further replies.
Classic28
Brandon
Maryland
Nissan Titan
Just seeing this, I’m order #1209. Compressor works great!
Ah read it’s only for orders Feb 14th and after, damn. 🤦🏻‍♂️
Tricky Dick
Dick
PNW
www.TD-Distributing.com
BostonSasquatch
Randy
Boston
Bronco Lux Badlands with hardtop and Sasquatch
Seeing as you include this advisory, " You can still air up a single flat if you need to, but the duty cycle dwindles to 2min doing 1 tire at a time. Airing up an entire vehicle, 1 tire at a time, will damage the Trickflate. It just simply puts out too much air and is optimized for 4 tires at a time," you also include (or provide as an option?) this single-tire hose:
Ford Bronco Trickflate Giveaway! 1677198744302
Aren't you sort of encouraging abuse (misuse) of your compressor by including this hose? And if a 2-way or 4-way system's chucks default to closed, can't a user simply attach a single chuck to a valve stem and inflate that one tire?
Asking for a friend myself.
Tricky Dick
Dick
PNW
The hose is a freebie from the manufacturer and gets the job done, it's just not optimal. I myself have been using mine with the included hose all this time and have run longer than recommended, I'm just encouraging an upgrade for optimal life and to get the duty cycle back up to 100%. The problem is that a single valve stem can't pass the full volume of air so it puts a lot of backpressure on the unit, so using a 4 way with only one chuck open doesn't help the flow either.
Dmorty217
Derek
Venice FL
Camery
I can confirm this compressor and also the tie rod repair kit are worth every penny. Good luck to those who purchased/entered. @Tricky Dick can you recommend a 4 tire inflate kit?
BostonSasquatch
Randy
Boston
Any feedback on those traction boards in mud? I had a major wallow in Utah. Rhino USA boards failed me utterly. I'm not embarrassed to report that some Samaritans in an Explorer pulled me out.
Tricky Dick
Dick
PNW
Also the Trickflate, like is cousin the Maxi Trac, are something of a base project loaded with potential. There is a whole community of modders that trick these out.
I do have a Trickflate Pro in the works which will come with a pressure cutoff switch and standard quick disconnect to go more toe to toe with the Morrflate.
Tricky Dick
Dick
PNW
I haven't heard much about mud performance so I can't really comment.
Mlarv
TN
2023 Bronco/ 2022 F150/ 1968 Mustang
I just ordered but forgot the B6G discount code. Order #1388
Thanks Mike
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I've sent out a fair amount of compressors last week but only have 2 entrants. @351W-Bronco and @BulldogBuck, those 50% odds are looking pretty nice eh?
You’ll have to forgive your customers for thinking you’re up to no good… Tricky Dick‘s past doesn’t have a positive track record…
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
His past is rocky and stuck between 2 rocks and a hard place.
I will be single tire filling with mine for the rest of the compressors life. Those full 4 at a time things take to long to set up.
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 23 Bronco
Order #1419
I'll need to DIY a 4 tire inflation setup.
Tricky Dick
Dick
PNW
Status
