Mud flaps/ Splash guards for Outerbanks
tbohland
Thomas
Novi MI
2014F150
Aoben rivet nut tool f
you are correct. If i had that tool I would have added the extra bolt on each bracket. Once the step its moved back an inch it just looks right, and the mudflaps do a great job in this Michigan weather! Please post pics when you get that rivit tool, maybe I will add the extra bolts too!
geoking
george
Huntsville,AL
2020 GT500 , 2020 F150, 1934, 1948, 1958 , 1966
I’m trying to find front mud flaps that will fit my soon to be delivered Outerbanks. It appears that the sidesteps interfere with the Ford splash guards. Any suggestions for other options?
Please find below picture of Ford Mud mud flaps with the Tube step that comes on the Outerbanks. You can do this with a drill , dremel and a file by moving the mounting holes in the bottom of the tube step. .
Ford Bronco Mud flaps/ Splash guards for Outerbanks 5012D813-1769-4977-89F8-54F0E307915E
tbohland
Thomas
Novi MI
2014F150
actual was 1-1/8”
BroncoScott
Duston
Jacksonville, FL
2021 Ford Bronco Outer Banks Wrapped Lifted Shoes
Anyone know if there is a set of mud flaps available now that doesn't require moving the side step? I assumed by now there would be several on the market.
frogier
Frank
1998 Jeep ZJ Limited 5.9L
I run Weathertech Front mud flaps. They don't look the best but they do work.
tjnoffy
Jay
Maryland
'21 Bronco OBX Sas, '22 Escape Hybrid, 2 Harleys
Rokblokz released some, but they've been sold out every time I check. Hopefully production will catch up with demand at some point. Supposed to fit Sasquatch and non-Sasquatch models. Available is short and long. Looks like the front flaps would come down in front of tube steps if you have them, as I do.
https://rokblokz.com/products/ford-bronco-2021-mud-flaps
Madeitthisfar
Washington, DC
2023 OBX Bronco 4dr; 2021 Honda CR-V Hybrid
How did you get them to fit properly? I’m assuming yours is an OBX based on the flair? I attached mine yesterday, but had to remove the OEM tube step on my OBX and it doesn’t fit quite right.
Ford Bronco Mud flaps/ Splash guards for Outerbanks A1AE994C-FFFA-44F5-9063-C76ECED372AE
Ford Bronco Mud flaps/ Splash guards for Outerbanks 3283643D-DA49-4879-9A15-08BACC95BCE5
Ford Bronco Mud flaps/ Splash guards for Outerbanks 6A93533E-B1CC-4F13-93BE-FB4EFEEA2658
Ford Bronco Mud flaps/ Splash guards for Outerbanks 8DD62D79-3363-405D-8833-42DD6E437385
